Daniel avatar image
Daniel asked
Simple Speechrecognizer example to run with CURL
Hello all, I am failing to post a simple request to the recognize request (I'm using the Postman Chrome Extension to try things out). Here are my header and body: HEADER POST /v1/avs/speechrecognizer/recognize HTTP/1.1 Host: access-alexa-na.amazon.com Content-Type: multipart/form-data; boundary=86371ffc080fbb6fc614e8e36d0b8a4d Authorization: Bearer Atza|IQEB... Transfer-Encoding: chunked Cache-Control: no-cache BODY --86371ffc080fbb6fc614e8e36d0b8a4d Content-Disposition: form-data; name="request" Content-Type: application/json; charset=UTF-8 { "messageHeader": { "deviceContext": [ { "name":"playbackState", "namespace":"AudioPlayer", "payload": { "streamId": "1", "offsetInMilliseconds": "0", "playerActivity": "IDLE" } } ] }, "messageBody": { "profile": "alexa-close-talk", "locale": "en-us", "format": "audio/L16; rate=16000; channels=1" } } --86371ffc080fbb6fc614e8e36d0b8a4d Content-Disposition: form-data; name="audio" Content-Type: audio/L16; rate=16000; channels=1 5249 4646 b80a 0200 5741 5645 666d 7420 1000 0000 0100 0100 803e 0000 007d 0000 0200 1000 4c49 5354 1a00 0000 494e ... --86371ffc080fbb6fc614e8e36d0b8a4d-- RESPONSE { "error": { "code": "com.amazon.alexahttpproxy.exceptions.InternalServerError", "message": "Request could not be executed due to an internal service error." } } As the response is rather generic about the error occured I am assuming that the wav file might be the issue. The link to the wav file: http://zank.s3.amazonaws.com/alexa-what-time-is-it-16bit-16hz-mono-pcm.wav It simply says "alexa, what time is it?" 16bit, 16000Hz, mono, pcm. Can anyone help?
alexa voice service
E. McDonald avatar image
E. McDonald answered
I believe if you change the "streamId": "1" to "streamId": "" it will work.
Eric@Amazon avatar image
Eric@Amazon answered
E. McDonald is correct - when there is no stream playing, the streamId should be an empty string. Has that fixed your problem? -Eric
Daniel avatar image
Daniel answered
Thank you, that does make sense but didn't seem to be obvious to me. After setting "streamId" to an empty string, I get "204 - No Content". Why don't I get a response?
I actually have a complete curl example that might help, see https://gist.github.com/carsonmcdonald/4151ba9b5d5ba8e983b8 Just change the AT value to a valid auth token and the test.wav to your wav filename.
Daniel avatar image
Daniel answered
E. McDonald, this is awesome, exactly what I was looking for. I works, with my wav file as well, thank you!
