bporch5053 avatar image
bporch5053 asked
500 Internal Server Error
Can anyone shed light on what is wrong with this request? I can successfully authenticate but I am receiving a 500 Internal Server error when I post a recognize request. Headers: POST /v1/avs/speechrecognizer/recognize HTTP/1.1 Accept: */* Authorization: Bearer Host: access-alexa-na.amazon.com Content-type: multipart/form-data; boundary=---------------------------boundary Transfer-Encoding: chunked Body: ---------------------------boundary Content-Disposition: form-data; name="request" Content-Type: application/json; charset=UTF-8 { "messageHeader": { "deviceContext": [ { "name": "playbackState", "namespace": "AudioPlayer" "payload": { "streamId": "", "offsetInMilliseconds": "", "playerActivity": "IDLE" } } ] }, "messageBody": { "profile": "doppler-scone", "locale": "en-us", "format": "audio/L16; rate=16000; channels=1" } } ---------------------------boundary Content-Disposition: form-data; name="audio" Content-Type: audio/L16; rate=16000; channels=1 ---------------------------boundary--
alexa voice service
vikramezhil avatar image
vikramezhil answered
Just out of curiosity what did you pass in the scope data for [b]PRODUCT_ID[/b] & [b]PRODUCT_DSN[/b] ?
invoxia avatar image
invoxia answered
"namespace": "AudioPlayer" is missing a terminating comma, isn't it ?
bporch5053 answered
Thanks for the catch. I corrected that but it didn't solve the issue.
bporch5053 answered
Product ID is 'AlexaLink' Product DSN is '1234' for testing purposes.
invoxia answered
Hmm... I would say that the boundaries in the body are missing a heading double-dash: if your boundary is '---------------------------boundary' (with 27 '-') you should get '-----------------------------boundary' (with 29 '-') in the body (or possibly you meant to have a 25-dash boundary ? so you have to remove 2 dashes in the Content-Type header)
Beefalo avatar image
Beefalo answered
Per the previous comments: 1) Missing comma after "namespace":"AudioPlayer" -- sounds like you already fixed this 2) Double check your boundaries, should be: boundary= -- -- -- -- 3) The audio should be sent up as raw LPCM and NOT base64-endoded
bporch5053 answered
I got this working. Turns out that the multipart format is particular about '\r\n" line terminators. Thanks!
Daniel avatar image
Daniel answered
Can you elaborate on how to send the Audio file as Raw LPCM instead of base64_encoded? How would you do that eg. with curl? Thanks!
Eric@Amazon avatar image
Eric@Amazon answered
Daniel, does this thread help? https://forums.developer.amazon.com/forums/message.jspa?messageID=19142#19142 From your other post in [i]Simple Speechrecognizer example to run with CURL[/i], it seems as though you have a PCM file to test with - just remember not to include the WAV's headers when sending the data. -Eric
Daniel avatar image
Daniel answered
Hi Eric, I have a PCM file but I seem to have troubles understanding how exactly I have to go from the wav file to some kind of a string to put into the request. I currently assume I have a correct PCM file (I've linked it to the [i]Simple Speechrecognizer example to run with CURL[/i] thread) but I'm missing the step getting it from the file into the request. What I've been doing so far is simply opening the wav file in a text editor, selecting all, copy and paste it into the request body (which seems to be not working especially when you mention NOT to include the wav headers). I feel stupid, but how would I do that? I know this sounds stupid, but how?
