Franck LEFEVRE avatar image
Franck LEFEVRE asked
redirect_ui returns access token with # instead of ?
Hello, After the authentication, the redirect returns access token with # instead of ? I wonder if this issue has been figured out? What is the problem? Here's the request: https://www.amazon.com/ap/oa?client_id=amzn1.application-oa2-client.XXXXXXeb92e48858bd10f0a16a2f57d&scope=alexa%3Aall&scope_data=%7B%22alexa%3Aall%22%3A%7B%22productID%22%3A%22timesquair%22%2C%22productInstanceAttributes%22%3A%7B%22deviceSerialNumber%22%3A%221234567890%22%7D%7D%7D%3B&response_type=token&redirect_uri=https%3A%2F%2Fapi.timesquair.io%2Fapi%2Fxxx%2Favs_return Here's the redirect after authentication: https://api.timesquair.io/api/jedi/avs_return#access_token=Atza%7CIQEBLjAsAhRc2LHB9NMhhrcnWMr1RRRNtH89hAIUDZNQe5jGWIkipooJWgFl7Vv_8SDSgytxif-qQ5hG6wMkExkwMx6rpgwvWi8HWiZPkfYd_nDvBByGKXxDRUdzpFL6A_rts2MjgBQ_SfIn049OyUiULzcOWW-deoR6_6BnjCk1pYAynNxn0jtcV8EQuNarBgG8PO6lPaDNUah6Tcr97x9HVXR6trdGjbFjGv-Gkq-28I9H_dN4JKBasqSPjlDvwsGS1HEC1knKgMwD_lWcAGA6De7w3PLrewyLYe1U71ntiLnL-R2nsGfklQD1N8E269O3YZuJWRS44Xps0L0SPCN3jz_j3rWM2D91uAdu8kku3QypPu7yywO95oMA3bFv8heCkHesfzpG9W6oRZaJhkfGwQ&token_type=bearer&expires_in=3600&scope=alexa%3Aall I've seen the threads: https://forums.developer.amazon.com/forums/thread.jspa?threadID=9305&tstart=0 and https://forums.developer.amazon.com/forums/thread.jspa?messageID=23745? but they are not closed... Thanks for your help. Franck.
alexa voice service
Franck LEFEVRE answered
Note that this problem only occurs when trying to get "Implicit grant". "Authorization Code Grant" works fine... Best rgds. F.
Eric@Amazon avatar image
Eric@Amazon answered
Hi Franck, Just wanted to let you know we haven't forgotten about you! I'm looking into the issue, and I'll update this thread once I find out what's going on. In the meantime, have you tried using one of the other ways to authenticate with AVS (Android app, iOS app)? Thanks for using AVS!
I have an answer for you! This is expected behavior - it follows the OAuth spec ( https://tools.ietf.org/html/rfc6749#section-4.2 - see part B and C). Implicit grants are returned in a fragment, not as a query string. If you need to use the authorization code server side, you will need to use Authorization Code Grant. Message was edited by: Eric@Amazon
