Sudhindra avatar image
Sudhindra asked
HTTP 500 or BAD Request on a .net client app
Hi Experts, I am trying to get a .net client to invoke alexa voice service. I tried using the sample reference app to invoke the [b]/speechrecognizer/recognize api[/b] So far, I have tried two approaches in the .net client code. 1. use a Stream Content and dump all content into a stream (like the java reference app/ sample app). This always results in a a bad request error. 2. Use a MultiPart form content and add string content and the media content and send the request. This results in a HTTP 500 error. from the service. I am not certain, what I am doing wrong here. any thoughts/ pointers ?
alexa voice service
Eric@Amazon avatar image
Eric@Amazon answered
Can you supply us with examples of each type of request? As a general note, one possible cause of 500 errors is bad audio data. Make sure that the data you're sending to Alexa is 16kHz, mono PCM audio.
Sudhindra answered
Hi, I am not able to reproduce the Bad Request Error from my test console. But for the Internal Server error, I was able to get the following capture: [b]Begin Request[/b] POST https://access-alexa-na.amazon.com/v1/avs/speechrecognizer/recognize HTTP/1.1 Authorization: Bearer [i]OAuth Token[/i] Content-Type: multipart/form-data; boundary="1BOUNDARY1" Host: access-alexa-na.amazon.com Connection: Keep-Alive Content-Length: 76946 --1BOUNDARY1 Content-Type: application/json; charset=utf-8 Content-Disposition: form-data; name=request {"messageHeader": {"deviceContext": [{"name": "playbackState","namespace": "AudioPlayer","payload": {"streamId": "0","offsetInMilliseconds": "10","playerActivity": "IDLE"}}]},"messageBody": {"profile": "alexa-close-talk","locale": "en-us","format": "audio/L16; rate=16000; channels=1"}} --1BOUNDARY1 Content-Type: audio/L16; rate=16000; channels=1 Content-Disposition: form-data; name=audio [i]mono 16000 Hz 16bit PCM Audio file stream[/i] --1BOUNDARY1-- [b]End Request[/b] for this request I get a response : [b] Connection: keep-alive x-amzn-RequestId: 692d1313-63b5-11e5-a513-d39f82332c77 x-amzn-ErrorType: InternalServerError: https://developer.amazon.com/edw/home.html Vary: Accept-Encoding, User-Agent Date: Fri, 25 Sep 2015 18:44:11 GMT Server: Server {"error":{"code":"com.amazon.alexahttpproxy.exceptions.InternalServerError","message":"Request could not be executed due to an internal service error."}} [/b]
Sudhindra answered
I also did log the entire request to text file and can share that too if required.
I think I see the problem. You're specifying the boundary as "\"1BOUNDARY1\"", instead of "1BOUNDARY1". In Content-type, it should be this: boundary=1BOUNDARY1 Did that fix it?
E. McDonald avatar image
E. McDonald answered
What happens if you set streamId to blank instead of 0? So "streamId": "" instead of "streamId": "0"
Thanks E. McDonald - good catch. The streamId should be blank instead of 0.
by LennySh avatar image
by LennySh answered
Can you post a sample of your code? I can't even get as far as you with .NET. I'm getting a Server Error 400 Bad Request.
by LennySh answered
Ok, I'm now getting a response... Just having trouble understanding how to handle the response... Message was edited by: by LennySh
by LennySh answered
Nevermind, I finally figured out how to get the audio response and play it back.
newalexadeveloper avatar image
newalexadeveloper answered
Just stumbled upon this thread. Can anyone share sample code for this in .NET?
