frenchy84 avatar image
frenchy84 asked
regCode not found
Hi, I followed every steps of the Reference Implementation Guide precisely and I got the same error every time I tried running the client and pasting the url given by the client: https://localhost:3000/device/register/XXXXXXXXXXXXXXXXXXXXX in Chrome, Firefox or Internet Explorer, I get: "error: Registration code is invalid" On the server command window, I get: Listening on port 3000 auth.validate matched whitelisted url entering register regCode no found Failure: Registering device: InvalidRegistrationCode: Registration code is invalid name: 'InvalidRegistrationCode', message: 'Registration code is invalid', status: 401 What did I miss? Can anyone help? Thanks, Frenchy Message was edited by: frenchy84
alexa voice service
frenchy84 answered
Alright so I tried re-generating the self-signed certificate for the server as documented. I went to \samples\service\ssl and deleted the old files and followed all the steps again from the Reference Implementation Guide. But I got an error in the final step when doing “keytool -import -v -trustcacerts -alias avs-companion-service -file server.crt -keystore "%JAVA_HOME%\jre\lib\security\cacerts" -keypass changeit -storepass changeit”. From the command prompt: keytool error: java.lang.Exception: Certificate not imported, alias already exists java.lang.Exception: Certificate not imported, alias already exists at sun.security.tools.keytool.Main.addTrustedCert(Main.java:2644) at sun.security.tools.keytool.Main.doCommands(Main.java:1006) at sun.security.tools.keytool.Main.run(Main.java:340) at sun.security.tools.keytool.Main.main(Main.java:333)
frenchy84 answered
FIXED. My token alias was expired or corrupted. 1-I deleted it from the command prompt: keytool -delete -alias avs-companion-service -keystore %JAVA_HOME%\jre\lib\security\cacerts 2-Password to enter was "changeit" 3-Created a new one with: keytool -import -v -trustcacerts -alias avs-companion-service -file server.crt -keystore "%JAVA_HOME%\jre\lib\security\cacerts" -keypass changeit -storepass changeit And everything worked fine.
elstryan@Amazon avatar image
elstryan@Amazon answered
That's great! I'm glad you were able to resolve this and thank you for writing up these steps in case another developer runs into this.
frenchy84 answered
Oups forgot the " " on the previous message. Here's the correct command: 1-I deleted it from the command prompt: keytool -delete -alias avs-companion-service -keystore "%JAVA_HOME%\jre\lib\security\cacerts"
frenchy84 answered
I've had the same error again and I realized I forgot to delete the old deviceSecret code and regcode IDs from the config.json before deleting the old alias: 1-Open \samples\javaclient\config.json 2-Delete ,"deviceSecret":"YYYYYYYYYYYYYYYY","regcode":"XXXXXXXXXXXXXXXXX" so it just looks like: {"pid":"my_device","serial":"123456","url":"https://localhost:3000"} 3-Save
