Leonard Shoell avatar image
Leonard Shoell asked
Reference Implementation - Error starting client
I'm following the Reference Implementation Guide. I'm doing a website implementation, running on Win 7. Everything has worked until I use the following command to start the client. mvn exec:exec -Dalpn-boot.version=8.1.7.v20160121 This command results in the following error: Failed to execute goal org.codehaus.mojo:exec-maven-plugin:1.2.1:exec (default-cli) on project sample-java-client: The parameters 'executable' for goal org.codehaus.mojo:exec-maven-plugin:1.2.1:exec are missing or invalid I've Googled and double checked everything, but I haven't been able to resolve this problem and would appreciate any help. Here is the full output with the "-e" option: C:\Alexa\AlexaVoiceServiceExamples\samples\javaclient>mvn exec:exec -e -Dalpn-boot.version=8.1.7.v20160121 [INFO] Error stacktraces are turned on. [INFO] Scanning for projects... [INFO] [INFO] ------------------------------------------------------------------------ [INFO] Building Alexa Voice Service Sample Java Client 1.0 [INFO] ------------------------------------------------------------------------ [INFO] [INFO] --- exec-maven-plugin:1.2.1:exec (default-cli) @ sample-java-client --- [INFO] ------------------------------------------------------------------------ [INFO] BUILD FAILURE [INFO] ------------------------------------------------------------------------ [INFO] Total time: 0.748 s [INFO] Finished at: 2016-02-25T13:39:49-07:00 [INFO] Final Memory: 7M/18M [INFO] ------------------------------------------------------------------------ [ERROR] Failed to execute goal org.codehaus.mojo:exec-maven-plugin:1.2.1:exec (default-cli) on project sample-java-client: The parameters 'executable' for goal org.codehaus.mojo:exec-maven-plugin:1.2.1:exec are missing or invalid -> [Help 1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.codehaus.mojo:exec-maven-plugin:1.2.1:exec (default-cli) on project sample-ja va-client: The parameters 'executable' for goal org.codehaus.mojo:exec-maven-plugin:1.2.1:exec are missing or invalid at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80) at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288) at org.apache.maven.cli.MavenCli.main(MavenCli.java:199) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356) Caused by: org.apache.maven.plugin.PluginParameterException: The parameters 'executable' for goal org.codehaus.mojo:exec-maven-plugin:1.2.1:exec are missing or invalid at org.apache.maven.plugin.internal.DefaultMavenPluginManager.populatePluginFields(DefaultMavenPluginManager.java:641) at org.apache.maven.plugin.internal.DefaultMavenPluginManager.getConfiguredMojo(DefaultMavenPluginManager.java:594) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:121) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207) ... 20 more [ERROR] [ERROR] Re-run Maven using the -X switch to enable full debug logging. [ERROR] [ERROR] For more information about the errors and possible solutions, please read the following articles: [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginParameterException
alexa voice service
Eric@Amazon avatar image
Eric@Amazon answered
Thanks for pointing this out! We'll fix the documentation. Launch the app with 'mvn exec:java' instead of exec:exec.
Leonard Shoell answered
Now I'm missing some runtime DLLs. Here's the error: [ERROR] The error was "Unable to load library 'libvlc': JNA native support (win32-x86/libvlc.dll) not found in resource path (C:\apache-aven-3.3.9\bin\..\boot\plexus-classworlds-2.5.2.jar)". [ERROR] [ERROR] The required native libraries are named "libvlc.dll" and "libvlccore.dll". When I grep my system, these DLLs are only in the folder "C:\Program Files\VideoLAN\VLC" I did get everything working by adding the following to the command line: -Djna.library.path="C:\Program Files\VideoLAN\VLC" While it is now working, I'm assuming these DLLs should also be located somewhere else, which could mean I didn't install something properly. What is the proper location for libvlc.dll and libvlccore.dll?
Your solution is the correct one for Windows - the libraries are exactly where they should be.
