When handling compound numbers that require more than one potential input (seven hundred fifty six thousand), we recommend you split the thousands, millions, etc. into different number slots. You can then handle the concatenation within your code after the intents are fulfilled.
An example: Intent Schema
{ "intents" : [ { "intent" : "GetNumber", "slots" : [{ "name" : "numberOneToNineHundredNinetyNine", "type" : "AMAZON.NUMBER" }, { "name" : "numberThousands", "type" : "AMAZON.NUMBER" }, { "name" : "numberMillions", "type" : "AMAZON.NUMBER" } ] } ] }
Sample Utterances
GetNumber {numberOneToNineHundredNinetyNine} GetNumber {numberThousands} thousand GetNumber {numberThousands} thousand {numberOneToNineHundredNinetyNine} GetNumber {numberMillions} million GetNumber {numberMillions} million {numberThousands} thousand {numberOneToNineHundredNinetyNine} GetNumber {numberMillions} million {numberOneToNineHundredNinetyNine}
From there, you will want to multiply any value in the GetNumber intent handler by their interpreted value (numberMillions * 1000000, numberThousands * 1000).
You can then add this to the numberOneToNineNineNine value to achieve your desired value.
Keywords: thousands, millions, compound numbers, large numbers
