From Android 5.0(API Level 21), RemoteControlClient API which was often used for media transport controls to the lockscreen has been deprecated. Media transport control buttons won't be shown on the lock screen with RemoteControlClient API with Android 5.0. Instead, Google has introduced a new API, MediaSession as its replacement. With the Notification.MediaStyle template introduced in Lollipop, it allows you to add media control as playback notification on the lock screen with greater control as to which buttons are displayed.
Documentation
Media Control Behavior Changes: http://developer.android.com/about/versions/android-5.0-changes.html#BehaviorMediaControl
MediaStyle Class Reference: http://developer.android.com/reference/android/app/Notification.MediaStyle.html RemoteControlClient(deprecated)
Class Reference: http://developer.android.com/reference/android/media/RemoteControlClient.html
Note that with Android 5.0, the system no longer shows RemoteControlClient objects on the lock screen.
Currently Google has not announced backwards compatibility for new MediaSession API. In order to add media control on the lockscreen for Android 4.0 and Android 5.0, you will need to add support for both RemoteControlClient API and MediaSessionAPI until minSdkVersion rises to 21 or higher. You can make the app distinguish which API to use by the following code:
if ((Build.VERSION.SDK_INT >= Build.VERSION_CODES.ICE_CREAM_SANDWICH) && ((Build.VERSION.SDK_INT < Build.VERSION_CODES.LOLLIPOP))) { // your code using RemoteControlClient API here - is between 14-20 } else if(Build.VERSION.SDK_INT >= Build.VERSION_CODES.LOLLIPOP) { // your code using MediaSession API here - is api 21 or higher }Keywords: Media Control, MediaSession, Lockscreen, deprecated methods
[KB_0032]
