This Unity / C# sample demonstrates encryption of the game public key and the client public key. The sample uses Bouncy Castle crypto libraries (https://bouncycastle.org/)
using System; using System.Security.Cryptography; using System.Text; using Org.BouncyCastle.Crypto; using Org.BouncyCastle.Crypto.Parameters; using Org.BouncyCastle.Security; namespace crypto { class Program { static String gamePublicKey = "<your_game_public_key_here>"; static String clientPublicKey = "<players_generated_1024_pkcs8_here>"; static void Main(string[] args) { // build key var rsaParameters = base64ToRsaParameters(gamePublicKey); // init crypto RSACryptoServiceProvider rsa = new RSACryptoServiceProvider(); rsa.ImportParameters(rsaParameters); // Use gamePublicKey // encrypt var encryptedData = rsa.Encrypt(Encoding.UTF8.GetBytes(clientPublicKey), false); var encryptedPayload = Convert.ToBase64String(encryptedData); Console.WriteLine(encryptedPayload); } static RSAParameters base64ToRsaParameters(String cryptoKey) { byte[] publicKeyBytes = Convert.FromBase64String(gamePublicKey); AsymmetricKeyParameter asymmetricKeyParameter = PublicKeyFactory.CreateKey(publicKeyBytes); RsaKeyParameters rsaKeyParameters = (RsaKeyParameters)asymmetricKeyParameter; RSAParameters rsaParameters = new RSAParameters { Modulus = rsaKeyParameters.Modulus.ToByteArrayUnsigned(), Exponent = rsaKeyParameters.Exponent.ToByteArrayUnsigned() }; return rsaParameters; } } }
