Vladimir Mavs avatar image
Vladimir Mavs asked
How can I play mp3 file in loop like noise?
I'd like to find solution to play one mp3 file in loop without any breaks.
The first way is using Alexa's SSML, how I understand I can't do that for my aims.
The second is using Player directives 'PlaybackNearlyFinished'. However in this approach, I see 3-7 seconds break between uploading the mp3.
I thought, that I can use InputStream for this purpose, but I didn't find any possibilities for that.
If you can suggest any approaches, it will be great.
Is it possible to do this? Will I listen pauses between loops anyway?
Thanks in advance,
Vladimir
alexa skills kitaudioaudioplayerssml
Brian@Amazon avatar image
Brian@Amazon answered
Hi Vladimir. Using PlaybackNearlyFinished is your best bet. You might get a little bit of buffering based on network speed and file size, but it's the best way to implement this looping behavior.
Thanks a lot for answer!
