Antonio avatar image
Antonio asked
That command doesn't work on device... (failing to control device after discovery)
After discovery I can see my device but I cannot control. Any attempt like:
alexa turn on the [device-name]
end up with the following message:
The lambda doesn't receive any event so I'm doubting that there is something wrong in my discovery response... This is the capability I'm returning during discovery for the device I'm trying to control.
Initially I was not returning the properties object.. but even after adding it the result did not changed
    'type': 'AlexaInterface',
    'interface': 'PowerController',
    'version': '3',
    'properties': {
        'supported': [
                'name': 'powerState'
What are the possible reason for receiving this message?
alexa skills kitdevicescontroller
        'endpointId': 'device_id_here',
        'manufacturerName': 'manufacturer',
        'friendlyName': 'device_name_here',
        'description': '',
        'displayCategories': ['SWITCH'],
        'capabilities': [
                'version': '3',
                'properties': {
                    'supported': [
                        {'name': 'powerState'}
                'proactivelyReported': True,
                'retrievable': True
        'cookie': {'aaa': 'bbb'}
if it helps here is the list I'm reporting containing only one device, I tried also adding proactivelyReported and retrievable.. but result didn't change
Antonio answered
My bad.. The interface was Alexa.PowerController and not simply PowerController
