Alex avatar image
Alex asked ·
Echo show "camera isn't responding"
Hi..
it is my sencord question.
I already asked to Amazon customer service but no response. :(
I made a testing environment with rtsp camera + live555 proxy server + stunnel.
I succeed the communication until RTSP DESCRIBE message.
but no any more message from ehco show. i tryied to dump the packers.
echo show sent FIN/ACK packet then disconnected.
FYI, it a my lambda response message.
{ "event": { "header": { "messageId":"69c50a8e-d7f2-4dcf-aa85-e28c63885770", "namespace":"Alexa.CameraStreamController",
"name":"Response",
"correlationToken":"AAAAAAAAAAAn4Clhf7r/AR.....",
"payloadVersion":"3"
"endpoint": { "endpointId":"0c001100002" },
"payload": {
"cameraStreams":
"uri":"rtsp://mydomain.com:443/proxyStream",
"expirationTime":"2017-12-31T16:20:50.52Z",
"protocol":"RTSP",
"resolution": { "width":1280, "height":720 },
"authorizationType":"NONE",
"videoCodec":"H264",
"audioCodec":"G711" }
"imageUri":"https://s3.sammachin.com/loading.jpg" }
I changed my real camera URL only.
I think the SSL connection is no problem because i can receive the DESCRIBE message.
and it is the response of DESCRIBE request.
RTSP/1.0 200 OK
CSeq: 1 Date: Sat, Nov 18 2017 01:25:22 GMT
Content-Base: rtsp://mydomain.com:443/proxyStream/
Content-Type: application/sdp
Content-Length: 514
v=0
o=- 1510968235968441 1 IN IP4 10.117.224.138
s=LIVE555 Streaming Media v2017.10.28
i=LIVE555 Streaming Media v2017.10.28
t=0 0
a=tool:LIVE555 Streaming Media v2017.10.28
a=type:broadcast a=control:*
a=range:npt=0-
a=x-qt-text-nam:LIVE555 Streaming Media v2017.10.28
a=x-qt-text-inf:LIVE555 Streaming Media v2017.10.28
m=video 0 RTP/AVP 96 c=IN IP4 0.0.0.0 b=AS:50
a=rtpmap:96 H264/90000
a=control:track1
m=audio 0 RTP/AVP 97
c=IN IP4 0.0.0.0
b=AS:50
a=rtpmap:97 PCMA/8000
a=control:track2
The response time is not over 1 second now.
what's wrong? i spent so many time to dubug this issue.
Please let me know some guide.
Thanks,
Alex
echo showvideo skill api
2 comments
You ever solve this? I can't. I can't even see why my rtsp is erroring out within Echo Show. I have no way to debug it. The developer site under test just says 'cameras are not supported on this device' when I try.
Hello Will,
Can you share skill id with us I will take a look?
Mykroft avatar image
Mykroft answered ·
Any chance you could share any of the details or source? I am trying to do exactly this and you are much further along.
I feel you are right in that you would not be communicating at all if it were a TLS issue. So stunnel appears to be a good option.
I'm not going to be much help here, but...
Can VLC or another client see video through the live555 proxy? I mean it almost just seems like a proxy error or proxy configuration problem.
Can VLC or another client see video directly to the camera?
Here, https://developer.amazon.com/docs/smarthome/build-smart-home-camera-skills.html , it sounds like you are required to spell out height and width separately?
Does Discovery work?
I don't have enough experience to really help you, but I'm interested in figuring this out, so I can try to keep the conversation going...
I am attempting to use a SnapAV Luma NVR, but not very optimistic. This custom stuff is hard work.
KAIYIN@AMAZON.COM avatar image
KAIYIN@AMAZON.COM answered ·
Replied in the contact-us as well. Try set authorizationType" from "NONE" but "BASIC".
Did anyone ever figure this out? No matter what I do I always get 'Hmmmmm.....Kitchen camera is not responding'. My RTSP stream is fine via VLC
newuser-81079dd9-74e3-40ba-a8a1-783ce9de1ee9 avatar image
newuser-81079dd9-74e3-40ba-a8a1-783ce9de1ee9 answered ·
Have you figure this out?
newuser-74f6365d-fd45-4da7-b5b9-b3e0fb9a92bc avatar image
newuser-74f6365d-fd45-4da7-b5b9-b3e0fb9a92bc answered ·
Hi,Have you solved your problem?I have the same problem,but my SSL is fine,however,I'm using SSL_read and it returns 0,I can't read anything,Should the server send something to echo show before using SSL_read?Thanks.
