Andrew W Harteveldt avatar image
Andrew W Harteveldt asked
Alexa app says "There was a problem" when controlling a device, even though all was good!
alexa skills kitdevices
Jenn@amazon avatar image
Jenn@amazon answered
Even though the request was successful to the device, it sounds like the confirmation response to Alexa wasn't correct.
@Jenn@amazon
I am still seeing this issue, and have validated my response. I don't see any issue on our side. We holding off launching our v3 service as this will drive calls into our customer care team. In addition, we have customers in Canada that are awaiting our CA support, but we are unable to submit our existing COHO Skill for certification as all certifications are required to be COHO v3 now.
Please could you help us out ASAP as this has been going on a long time now.
Regards,
Andrew & Team.
HCA Dev Team avatar image
HCA Dev Team answered
Ok, this is the message received.
    "directive": {
        "header": {
            "namespace": "Alexa.PowerController",
            "name": "TurnOn",
            "payloadVersion": "3",
            "messageId": "c947f788-b591-40a5-a9b8-3d8d2a9a9069",
            "correlationToken": "ctokenremoved"
        "endpoint": {
            "scope": {
                "type": "BearerToken",
                "token": "tokenremoved"
            "endpointId": "BFRGG-36DT8-18",
            "cookie": {
                "objecttypetype": "Switch",
                "supportDim": "true",
                "identifier": "18",
                "wattage": "0",
                "folder": "Theater",
                "instanceID": "440",
                "hcaref": "design",
                "objecttypeid": "1",
                "name": "Theater Ring Lights",
                "typeid": "0",
                "typetype": "device"
        "payload": {}
and this is the response I send:
    "context": {
        "properties": [
                "name": "powerState",
                "value": "ON",
                "timeOfSample": "2017-11-30T00:30:31.671Z",
                "uncertaintyInMilliseconds": 0
                "namespace": "Alexa.EndpointHealth",
                "name": "connectivity",
                "value": {
                    "value": "OK"
                "namespace": "Alexa.PowerLevelController",
                "name": "powerLevel",
                "value": 100,
    "event": {
        "header": {
            "messageId": "f7379c61-69a0-45b4-8847-db8ed17d867d",
            "namespace": "Alexa",
            "name": "Response",
        "endpoint": {
            "scope": {
            "cookie": {
                "identifier": "18",
                "wattage": "0",
                "hcaref": "design",
                "typeid": "0",
        "payload": {}
nickmadge avatar image
nickmadge answered
have you tried it without the powerlevelController properties?
Yes, have tried also as some devices that are non dimmable are just PowerControllers.
Really strange... I copied your Response JSON into a Test SmartHome Skill and Alexa replies with an 'OK' to the Request.
Can you share the Skill ID so I can dig into a bit more?
Sure, and yes it is very strange. Note that Alexa says OK, but when performed through the Alexa app is where I have the issue.
Skill ID: amzn1.ask.skill.ef3e0047-0258-44ad-a2c6-4b8792813b35
Also, as an FYI, when I connect to my existing V2 COHO skill the message is not displayed, so this is definetly something that is V3 specific.
Still need assistance with this!
Andreas Richiger avatar image
Andreas Richiger answered
This seems to be a similar problem I asked for in How must response look like if Retrievable==false and ProactivelyReported==false?
The error message "There was a Problem" pops up in the alexa-app a couple of seconds after a smart home device has been operated via the app (click) on light bulp icon.
@Andi This is indeed the same issue I have. Did you get a solution to this?
Matias B avatar image
Matias B answered
Same issue. Alexa Support Team didn't give any answer
