Christian Schafleitner avatar image
Christian Schafleitner asked
MPEG2 decoding on the new Fire TV (2017) no longer supported?
Hi!
I have a very simple app that just plays back an MPEG2 stream coming from a Rasperry PI + OTA TV dongle. This app works totally fine on the 2nd generation Fire TV, but no longer works on the new 2017 Fire TV. The picture gets stuck after a 1-2 seconds. Sometimes it tries to decode some single frames, but definitely not working.
Is this behavior expected on the new Fire TV? It seems it is decoding in software, is there a way to enable the HW decoder, if there is one?
Thanks for your help, Christian
fire tv
Levon@Amazon avatar image
Levon@Amazon answered
Hi Christian,
Thanks for posting! Could you please clarify a couple of things for me? Is this an app that you built? If so, what are you using for decoding / playback: is it ExoPlayer, or something else? If you could login to your Dev Portal account, raise a "Contact Us" case with us, indicate your app name / ID, and the frameworks / technology you used to built it, we could look into this further.
Otherwise, if this is not your app, then please note that this is a forum for Amazon Appstore developers. For assistance with the Amazon Fire TV as an end user, please contact Amazon Customer Service for support (http://www.amazon.com/customerservice) or post in the Fire forums (http://www.amazon.com/forum/fire/). Thanks!
Christian Schafleitner answered
Thanks Levon,
It is an app that I built, but I haven't published it yet (I am in the prototyping stage). I tried using both the native VideoView and ExoPlayer. Same result.
My question is basically: Are you aware of any MPEG2 decoding issues (1080i source) and is there a way to work around them? Do you any sample video player apps
I only have this issue with the newest 2017 Fire TV, the old one works just fine.
Thanks, Christian
Thanks for additional details Christian,
I have forwarded your messages to the Fire OS team for review, and will update this thread when I hear back from them. Thanks!
Hi Christian,
Thanks for your patience. MPEG2 hardware decoding is coming in the next update. I don't have an ETA at the moment, but please keep an eye on your Fire TV updates. Thanks!
