newuser-f2e8c561-0e3e-4d53-a31c-1053867380a3 avatar image
CancelTestOrder endpoint gives an UnknownOperationException error
When I tried to cancel my test order, I encountered UnknownOperationException error. Could you give an example for request?
I used postman for request tool.
The endpoint that I used: https://dash-replenishment-service-na.amazon.com/testOrders/{slotId}
DELETE method is used for this operation and also body parameters are
x-amzn-accept-type: com.amazon.dash.replenishment.DrsCancelTestOrdersResult@1.0
x-amzn-type-version: com.amazon.dash.replenishment.DrsCancelTestOrdersInput@1.0
Authorization: Bearer (ACCESS_TOKEN)
Thanks,
Gizem
amazon developer portaldash replenishment service
Levon@Amazon avatar image
Levon@Amazon answered
Hi there,
Can you please provide a full example of the request with actual slot ID and access token? We just want to make sure that you actually put values into this fields and didn't use placeholders from documentation. Thanks!
