Hello all,
I had recommendations working on firetv and a firetv stick both of which seemed to work fine. After I added amazon specific extras the recommendations on both devices seem to be broken. I have read and re-read all the documentation on how to set up and post to the test recommendation row which does not seem to work either.
The only amazon extra I am using is com.amazon.extra.DISPLAY_NAME.
removing the extra and putting it back does not make any difference. I have reseted and rebooted, waited, navigated around, and tried a few other command line options from adb on trying to remove the cached info from the device none of which seems to work. It seems that the recommendations on these fire tv devices breaks after attempting so many times.
Is there anything I can do to force the test row to show up? Like I mentioned above I have tried all the suggested things mentioned in the documentation none of which work at all. I would rather not have to factory reset these devices.
Any help on the matter would be greatly appreciated.
