I can't figure out how to support querying for targetSetpoint in V3. In V2 there was the GetTargetTemperatureRequest, but what is the equivalent in V3? Any pointers?
Thanks.
Thanks.
A ‘ReportState’ Directive will be sent whenever user queries any of the temperatures : targetTemp or current temp reading.
In the ‘StateReport’ response, you should include all your 'retrievable' properties for:
(or whatever setpoints apply to your device)
I think then Alexa voice service will take care of responding back with just the Target Temperature if the user asked for that.
ok, I looked into V2 and realised the correct form to ask should be "Alexa, what is the device name set to?". Unfortunately I am having trouble with V3 finding the utterance examples. V2 was much clearer in that respect..
Yes, they definitely need to provide more example utterances and maybe a clearer flow of directives and responses. It takes some time to go through the big overhaul for V3.
think it's here:
https://developer.amazon.com/public/solutions/alexa/alexa-skills-kit/docs/alexa-temperaturesensor
To my understanding, that's the equivalent of GetTemperatureReadingRequest. GetTargetTemperatureRequest should provide the temperature to which the Thermostat has been set, and that's the function I can't find in the new V3 API: how to query for the temperature to which the thermostat is currently set.
I'm also having issues with providing the capabilities to show that a devices state can be retrieved...
likewise - pretty happy that the response is correct. I must be missing something?
{ "context": { "properties": [ { "namespace": "Alexa.TemperatureSensor", "name": "temperature", "value": { "value": 22, "scale": "CELSIUS" }, "timeOfSample": "2017-10-07T16:39:44.108Z", "uncertaintyInMilliseconds": 1000 } ] }, "event": { "header": { "namespace": "Alexa", "name": "StateReport", "payloadVersion": "3", "correlationToken": "dFMb0z+PgpgdDmluhJ1LddFvSqZ/jCc8ptlAKulUj90jSqg==", "messageId": "1bd5d003-31b9-476f-ad03-71d471922820" }, "endpoint": { "scope": { "type": "BearerToken", "token": "OAUTH-TOKEN-WAS-HERE" }, "endpointId": "184" } }, "payload": {} }
Anyone from Amazon help out here? I can't get ReportState working for thermostats - Interestingly, when I try opening the thermostat in the latest v of the Android app, it hangs that device and can't be re-queried
Properties:
{ "properties": [ { "namespace": "Alexa.TemperatureSensor", "name": "temperature", "value": { "value": 20, "scale": "CELSIUS" }, "timeOfSample": "2017-11-04T20:16:52.767Z", "uncertaintyInMilliseconds": 1000 } ] }
Also not getting back the set target temperature of my thermostat.
This is the response data for an Alexa Interface / ReportState request:
{ "event": { "header": { "messageId": "6163d6b7-6547-4bf7-8512-e783056866a0", "correlationToken": "xyz", "namespace": "Alexa", "name": "StateReport", "payloadVersion": "3" }, "payload": {}, "endpoint": { "scope": { "type": "BearerToken", "token": "xyz" }, "endpointId": "7" } }, "context": { "properties": [ { "namespace": "Alexa.ThermostatController", "name": "targetSetpoint", "timeOfSample": "2018-05-15T12:31:16Z", "uncertaintyInMilliseconds": 500, "value": { "value": 8, "scale": "CELSIUS" } } ] } }
Looks valid to me, but Alexa states that my device does not support this.
Any ideas?
Hi Christian,
Are you still having this issue? Do you have a Temperature Sensor capability on this device?
2 People are following this question.
