BergQuester avatar image
BergQuester asked
Crash when running with Xamarin Kindle IAP
Following the steps at https://developer.amazon.com/public/solutions/platforms/cross-platform/xamarin/docs/adding-a-plugin-to-your-xamarin-project
Getting this crash. What gives?
System.NotSupportedException: Could not activate JNI Handle 0x7fff3b91368c (key_handle 0x1cc5b91b) of Java type 'md58441721984586c4571cb9a14cde11b83/MainActivity' as managed type 'MyApp.Droid.MainActivity'. ---> System.TypeInitializationException: The type initializer for 'Builder' threw an exception. ---> Java.Lang.UnsatisfiedLinkError: dalvik.system.PathClassLoader[DexPathList[[zip file "/data/app/org.client.myApp-1/base.apk"],nativeLibraryDirectories=[/data/app/org.client.myApp-1/lib/x86_64, /vendor/lib64, /system/lib64]]] couldn't find "libAmazonIapV2Bridge.so"
  at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <183b200ee49746d48fc781625979428e>:0
  at Java.Interop.JniEnvironment+StaticMethods.CallStaticVoidMethod (Java.Interop.JniObjectReference type, Java.Interop.JniMethodInfo method, Java.Interop.JniArgumentValue* args) [0x00069] in <50812bf827614c0faffacac58772b4fa>:0
  at Java.Interop.JniPeerMembers+JniStaticMethods.InvokeVoidMethod (System.String encodedMember, Java.Interop.JniArgumentValue* parameters) [0x00018] in <50812bf827614c0faffacac58772b4fa>:0
  at Java.Lang.JavaSystem.LoadLibrary (System.String libname) [0x00029] in <71828dd8fb5f4508815e23d6996c45c2>:0
  at com.amazon.device.iap.cpt.AmazonIapV2Impl+AmazonIapV2Android.get_Instance () [0x00016] in <909e8c2781f24da69e9ca12b0195ac21>:0
  at com.amazon.device.iap.cpt.AmazonIapV2Impl+Builder..cctor () [0x00000] in <909e8c2781f24da69e9ca12b0195ac21>:0
  at java.lang.UnsatisfiedLinkError: dalvik.system.PathClassLoader[DexPathList[[zip file "/data/app/org.client.myApp-1/base.apk"],nativeLibraryDirectories=[/data/app/org.client.myApp-1/lib/x86_64, /vendor/lib64, /system/lib64]]] couldn't find "libAmazonIapV2Bridge.so
  at at java.lang.Runtime.loadLibrary(Runtime.java:366)
  at at java.lang.System.loadLibrary(System.java:988)
  at at mono.android.TypeManager.n_activate(Native Method)
  at at mono.android.TypeManager.Activate(TypeManager.java:7)
  at at md58441721984586c4571cb9a14cde11b83.MainActivity.<init>(MainActivity.java:26)
  at at java.lang.reflect.Constructor.newInstance(Native Method)
  at at java.lang.Class.newInstance(Class.java:1606)
  at at android.app.Instrumentation.newActivity(Instrumentation.java:1066)
  at at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2226)
  at at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2387)
  at at android.app.ActivityThread.access$800(ActivityThread.java:151)
  at at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1303)
  at at android.os.Handler.dispatchMessage(Handler.java:102)
  at at android.os.Looper.loop(Looper.java:135)
  at at android.app.ActivityThread.main(ActivityThread.java:5254)
  at at java.lang.reflect.Method.invoke(Native Method)
  at at java.lang.reflect.Method.invoke(Method.java:372)
  at at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:903)
  at at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:698)
  --- End of inner exception stack trace ---
  at at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_generic_class_init (intptr)
  at com.amazon.device.iap.cpt.AmazonIapV2Impl.get_Instance () [0x00001] in <909e8c2781f24da69e9ca12b0195ac21>:0
  at MyApp.Droid.AmazonIAPController..ctor () [0x00008] in /Volumes/HomeSSD/danielbergquist/src/app/MyApp/Droid/AmazonIAPController.cs:16
  at MyApp.Droid.MainActivity..ctor () [0x0000c] in /Volumes/HomeSSD/danielbergquist/src/app/MyApp/Droid/MainActivity.cs:20
  at at (wrapper dynamic-method) System.Object:891d7f60-510b-4b30-9cef-1fa96e87a12f (intptr,object[])
  at Java.Interop.TypeManager.n_Activate (System.IntPtr jnienv, System.IntPtr jclass, System.IntPtr typename_ptr, System.IntPtr signature_ptr, System.IntPtr jobject, System.IntPtr parameters_ptr) [0x000de] in <71828dd8fb5f4508815e23d6996c45c2>:0
iapandroid
Levon@Amazon avatar image
Levon@Amazon answered
Hi BergQuester,
Thanks for posting! The Xamarin plugin hasn't been modified for some time, so this exception is not because of some changes to it. What Android SDK version are you building this against? If fairly old, can you update to the latest? Do you have the latest support libraries? Are you accessing any properties in a method where those values have not been set yet (for example, trying to read Height or Width in the constructor, instead of OnDraw(), etc). Are you calling a method on an object that's null? Can you set breakpoints and try to debug your project step by step? Specifically put breakpoints on your class constructors and go from there. If you are sure none of those apply, have you tried to clean your project, or start a new one from scratch?
For reference, see also this SO thread: https://stackoverflow.com/questions/10593022/monodroid-error-when-calling-constructor-of-custom-view-twodscrollview
