Now my skill work ok in US but not in UK,lambda can not be called
I want make sure if I must have Europe endpoint ?thanks
You can use a single endpoint for both - it does not need to be based in Europe. What do you mean it can't be called? Does it have an error? Do you have a UK language version set up in the dev portal?
I just added Europe endpoint and then UK is ok = =;
lambda can not be called means: when I say discover devices,lambda can not be called,no log
Ah, a smarthome skill. Smarthome skills need an EU endpoint on eu-west-1, whereas custom skills do not.
No one has followed this question yet.
