tartan_guru avatar image
tartan_guru asked
Very slow response on "stop", "pause" and channel change commands
Alexa.PlaybackController "play" commands are passed to the lambda function with no discernible delay, however the equivalent "stop", "pause" or Alexa.ChannelController commands all have a delay of approximately 10 seconds before the lambda function is called. The lambda function has a timeout of 2 seconds so this isn't the issue and the times in logs confirm that the Lambda START request does not occur until 10 seconds after the voice command has been issued. This occurs on all my echo dot devices and on my third part triby device
Any ideas on what the issue could be?
response
Passed to relevant team.
tartan_guru answered
This issue seems to have resolved itself
