newuser-3dfe5d8e-c298-4bbf-aea1-b29592ad43d1 avatar image
Skills Kit not receiving directives
I'm working with the audioPlayer API. When I test, my lambda function seems to be returning the directives array with audio stream data, but I can't get my skill to receive it.
Lambda test responds with:
  "version": "1.0",
  "response": {
    "shouldEndSession": true,
    "card": {
      "type": "Simple",
      "title": "Playing Episode 140",
      "content": "Playing Episode 140"
    "directives": [
        "type": "AudioPlayer.Play",
        "playBehavior": "REPLACE_ALL",
        "audioItem": {
          "stream": {
            "url": "https://s3.amazonaws.com/<bucket>/<audio>.mp3",
            "token": "0",
            "expectedPreviousToken": null,
            "offsetInMilliseconds": 0
  "sessionAttributes": {
    "playOrder": [
      0,
      1
    "index": 0,
    "offsetInMilliseconds": 0,
    "loop": true,
    "shuffle": false,
    "playbackIndexChanged": false,
    "enqueuedToken": null,
    "STATE": "_PLAY_MODE"
Actual response received by skill:
  "version": "1.0",
  "response": {
    "card": {
      "content": "Playing Episode 140",
      "type": "Simple"
    "loop": true,
    "index": 0,
    "STATE": "_PLAY_MODE",
    "shuffle": false,
    "playOrder": [
      0,
      1
My Skill Information > Global Fields > Audio Player = Yes
And the mp3 successfully plays when I return it in an <audio> tag within the output speech.
I cannot figure out what is misconfigured. I've even set up and tested with the exact example which Amazon links, to no avail: https://github.com/alexa/skill-sample-nodejs-audio-player
lambdaapiaudioresponsenode_js
Nick Gardner avatar image
Nick Gardner answered
Are you doing this on a device or on the service simulator? If you're doing the latter can you please check if the same JSON is sent from an actual device test.
3 comments
i've tested with both. where can i check the logs when i try with an actual device?
Nick Gardner avatar image Nick Gardner ♦♦ newuser-3dfe5d8e-c298-4bbf-aea1-b29592ad43d1 ·
The logs won't be on the actual device, but you can create a logging function in your lambda to dump the entire request and response objects, which I find to be very helpful with debugging.
great! thanks nick, i'll look into it.
