newuser-79732c0c-940b-4ce1-a7f7-1efaf5982c2a avatar image
android app accesstoken expired
I get an accesstoken by authorizing from an AVS Product,and it works well.But the accesstoken expired after about one hour,how can i get a new one?Still use AuthorizationManager.getToken?Is there any api helping us to get the expired time?
alexa voice serviceandroid
Steve avatar image
Steve answered
You should consider using a refresh token, since they are valid indefinitely. You'll only need to refresh them on expiration. You can find more information about refresh tokens here:
https://developer.amazon.com/public/apis/engage/login-with-amazon/docs/refresh_token.html
5 comments
I absolutely understand your solution,but I didn't find the api to get a refresh token in login-with-amazon-sdk.jar.Should I use the method of https to get one?If so, why do Amazon developers not add an interface to login-with-amazon-sdk.jar?
nm@Amazon avatar image nm@Amazon newuser-79732c0c-940b-4ce1-a7f7-1efaf5982c2a ·
Hi @NewUser-79732c0c-940b-4ce1-a7f7-1efaf5982c2a You get the refresh token along with access token whenever you successfully login with amazon. Please also consider securely storing the refresh token.
I didn't find refresh token and no expired time in login-with-amazon-sdk.jar. I coded by reference to this:https://developer.amazon.com/public/apis/engage/login-with-amazon/docs/use_sdk_android.html
