sa0987 avatar image
sa0987 asked
Alexa - Echo - Toolkit - root certificate issue
I received, registered my app. Alexa clearly recognizes it exists. However it gives there error Request Identifier: amzn1.echo-api.request.d969c196-8b3e-4169-99c8-20f566889760 The certificate does not have a path to a trusted authority. This happens if you are using a self signed certificate. Voice feedback Echo heard: "alexa start myapp" I verified my COMODO CA (COMODO RSA Certification Auth) is on the list of authorized CA. I ensured my certificate bundle was valid. Is there anything specific I need to ensure my bundle.crt is in the correct order for Alexa? (there is no mention that .com is required, I am using .net) these my COMODO filenames. AddTrustExternalCARoot.crt COMODORSAAddTrustCA.crt COMODORSADomainValidationSecureServerCA.crt mydomain-net.crt ssl-bundle.crt stn.private.key Excited to get this to work ... please help SA
sa0987 avatar image
sa0987 answered
I am now able to communicate with Alexa without issues. the source of the problem was the order of the certs and the incorrect directives in SSL and HTTP config files for apache. I used openssl s_client -connect 192.237.1.1:443 to verify that the certificate Verify return code: 0 (ok) Initially I was able to confirm the error by code and searched and fixed it.
Nick Gardner avatar image
Nick Gardner answered
Glad you were able to fix it!
