Ravi avatar image
Ravi asked
Alexa : problem communicating with the requested application
Hi, I have created and enabled a test Alexa application using a Lambda function and the basic demo color intent code from the getting started guide. However when trying to access the application, i am getting the following error [b]Request Identifier: amzn1.echo-api.request.xxxxxxxxxxx There was a problem communicating with the requested application[/b] Please help Thanks
Ross@Amazon avatar image
Ross@Amazon answered
Abe avatar image
Abe answered
Hi Ravi If you are using AWS Lambda then you may need to add "Alexa Skills Kit" as an Event Source to your AWS Lambda Functions. Goto your AWS Function List Click on / In the next screen for "Event source type" select "Alexa Skills Kit" Click Submit Hope this helps Message was edited by: Abe
