newuser-7b31bc58-b49c-4155-9f70-f396db7b9d8b avatar image
should I register my product If the product is used for MIC,Speaker like headset?
Hi. I am developing a product which has mic,speaker to use alexa.
Also It is connected with Custom AVS app on Android phone.
If I use my product to input the voice and transfer it to AVS app on Android phone,
Should I register my product and get Authorization from Amazon?
to summarize it , the product like using as headset should be registered?
other question is that if I use Alexa on the product,
Is there any extra charge caused by lots of traffics ?
alexa voice serviceandroidtransfer app
swh avatar image
swh answered
Hello NewUser-7b31bc58,
It sounds like you may be asking whether a peripheral that records and forwards voice to an application that makes AVS requests needs to be registered separately from the application. If that is the case, the the answer is: no, it does not require separate registration. Only the product that actually makes the request to AVS needs to be authorized.
As for your last question, there is no charge for making requests to AVS.
I hope this helps,
-SWH
