I've followed the instructions to several different tutorials, using different zip files with different files, including those I'd written myself. I've also followed the instructions for compressing files via the command line interface, but I'm still getting the "TypeError: Cannot read property 'locale' of undefined" error:
START RequestId: f0f8c8c6-1645-11e7-813d-d13386de1364 Version: $LATEST 2017-03-31T19:12:12.139Z f0f8c8c6-1645-11e7-813d-d13386de1364 TypeError: Cannot read property 'locale' of undefined at AlexaRequestEmitter.HandleLambdaEvent (/var/task/node_modules/alexa-sdk/lib/alexa.js:103:38) at AlexaRequestEmitter.Object.defineProperty.value (/var/task/node_modules/alexa-sdk/lib/alexa.js:92:31) at exports.handler (/var/task/index.js:16:8) END RequestId: f0f8c8c6-1645-11e7-813d-d13386de1364 REPORT RequestId: f0f8c8c6-1645-11e7-813d-d13386de1364 Duration: 136.84 ms Billed Duration: 200 ms Memory Size: 128 MB Max Memory Used: 28 MB RequestId: f0f8c8c6-1645-11e7-813d-d13386de1364 Process exited before completing request
I found another discussion about the same problem, but the advice did not help.
Since this is a file I've not written, I have no control over it, nor am I inclined to attempt fixing it.
I've been at this for a couple of weeks, so I would appreciate some assistance here.
