newuser-803560cd-5257-4eed-b597-6b2891bd8a05 avatar image
Only default flash skill feed is playing
I'm testing a flash briefing skill that incorporates two separate feeds. Whichever feed is marked Default in the list will play, but the other does not. So far I've verified the following:
  • UUIDs are unique
  • Dates don't overlap
  • Feed types (JSON or RSS) are the same or different
  • Doesn't matter if the Content Type (TTS or audio) are the same or different
I can't think of anything else to check. Any ideas why this is happening?
alexa skills kitskillflash briefing
2 comments
Does this work for normal flash breifing skills for you? Like, ones already on the store, or is this just for your own skills?
newuser-803560cd-5257-4eed-b597-6b2891bd8a05 answered
Sorry, I didn't see your reply. I don't know if I have any other briefings installed from the store that incorporate more than one feed. I'll see if I can find one and install it.
