rahulzkuma avatar image
rahulzkuma asked
Unable to execute javaclient app
Hello Team, I am facing problem in executing the java client. I used "mvn exec:java" command but it throws some exception as: [WARNING] java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.codehaus.mojo.exec.ExecJavaMojo$1.run(ExecJavaMojo.java:297) at java.lang.Thread.run(Thread.java:745) Caused by: javax.json.stream.JsonParsingException: Invalid token=CURLYCLOSE at (line no=10, column no=5, offset=345). Expected tokens are: [STRING] at org.glassfish.json.JsonParserImpl.parsingException(JsonParserImpl.java:238) at org.glassfish.json.JsonParserImpl.access$1200(JsonParserImpl.java:61) at org.glassfish.json.JsonParserImpl$ObjectContext.getNextEvent(JsonParserImpl.java:291) at org.glassfish.json.JsonParserImpl$StateIterator.next(JsonParserImpl.java:172) at org.glassfish.json.JsonParserImpl.next(JsonParserImpl.java:149) at org.glassfish.json.JsonReaderImpl.readObject(JsonReaderImpl.java:177) at org.glassfish.json.JsonReaderImpl.readObject(JsonReaderImpl.java:184) at org.glassfish.json.JsonReaderImpl.readObject(JsonReaderImpl.java:103) at com.amazon.alexa.avs.config.DeviceConfigUtils.readConfigFile(DeviceConfigUtils.java:48) at com.amazon.alexa.avs.AVSApp. (AVSApp.java:63) at com.amazon.alexa.avs.AVSApp.main(AVSApp.java:58) ... 6 more [INFO] ------------------------------------------------------------------------ [INFO] BUILD FAILURE [INFO] ------------------------------------------------------------------------ [INFO] Total time: 1.558 s [INFO] Finished at: 2015-12-09T16:43:58+05:30 [INFO] Final Memory: 8M/19M [INFO] ------------------------------------------------------------------------ [ERROR] Failed to execute goal org.codehaus.mojo:exec-maven-plugin:1.2.1:java (default-cli) on project sample-java-client: An exception occured while executing the Java class. null: InvocationTargetException: Invalid token=CURLYCLOSE at (line no=10, column no=5, offset=345). Expected tokens are: [STRING] -> [Help 1] [ERROR] [ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch. [ERROR] Re-run Maven using the -X switch to enable full debug logging. [ERROR] [ERROR] For more information about the errors and possible solutions, please read the following articles: [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException Kindly have a look and help me on it. Thanks in Advance.
rahulzkuma answered
Hi Team, I re created the SSl certificates and followed the complete steps from implementation portal and its working now. But i would like to know the reason for the same error. Thanks,
swasey@amazon avatar image
swasey@amazon answered
You had a typo or something in your config.json file. Perhaps you were missing a quotation, or had an extra comma, I'm not sure, but that's what it was.
