chris avatar image
chris asked
Alexa iOS voice service -> Alexa Skills Kit failure.
As of December 11th our Alexa implementation worked perfectly. After successfully Logging in With Amazon, we were able to query Alexa with our skills kit specific questions in our iOS Alexa Voice Services product. That audio file was then successfully posted, our Alexa Skills Kit was consulted, our Amazon Lambda files were used, and the proper response was returned through Alexa to our app. Currently this no longer works. We are still able to Login With Amazon and query Alexa, but none of our Alexa Skills Kit skills are used. The only responses we are able to get from Alexa are her token responses. While debugging we used the Java Demo app(Amazon Provides) with our Alexa Voice Service product info to obtain a Amazon Access Token. We then used the access token obtained in the Java Demo app in our iOS app. Using this access token for our audio file HTTP Post the process again worked perfectly. Thoughts or suggestions?
chris avatar image
chris answered
The email used to log in on the iOS device must be either the email associated with the Developer account OR be given permissions by the developer account
