Alexa App shows image in the card when using the original feed of rss format.
ex) https://aws.amazon.com/new/feed/
But JSON format don't have key to specify image.
Is there any way to show image with JSON format?
The JSON format is not the source for the image, rather the image in the card comes from one you specify in the developer portal. You should find this option when you add a feed to your flash briefing skill.
No one has followed this question yet.
