newuser-5b2c9375-22f7-400e-a494-2a132ed617d5 avatar image
Alexa Skills Kit Web Service in Node.js and Deployed on Premise
I am reading Alexa Skills Kit for node.js , my requirement is to have the webservice handling the intents on a on-premise instance instead of Lambda . How can i achieve that with alexa Skills kit node.js library.
All the blogs point to the Alexa Skills Kit with implementation for Lambda.
Any pointers are kindly appreciated
alexa skills kitintentssdk
meep avatar image
meep answered
I did something similar in that I built my skill in node-red (on top of node.js) running on a local server.
I have a blog article about it here;
http://mediaserver8.blogspot.ie/2016/10/securing-skills.html
(check out some other posts around that date for related info)
Essentially, I set up an Apache instance with SSL cert and reverse proxy to my node-red install which runs in a docker. This covers the https endpoint requirement. Take care to use a cert. that's approved by Amazon - not all of them are.
Another option is to build a simply proxy in lambda that passes intents through Lambda to an external server. The advantage AND disadvantage here is that your skill can be built on a http server so no need to set up SSL certs but of course everything is over http and therefore wildly unsecure.
