Bailey avatar image
Bailey asked
Setting and Using Session Data
Hello, I am having trouble using session data I have set. I appear to be running into a ClassCastException: java.util.LinkedHashMap cannot be cast to com.amazon.speech.slu.Slot: java.lang.ClassCastException java.lang.ClassCastException: java.util.LinkedHashMap cannot be cast to com.amazon.speech.slu.Slot at com.philosowaffle.skill.bible.BibleSpeechlet.readChapter(BibleSpeechlet.java:356) at com.philosowaffle.skill.bible.BibleSpeechlet.onIntent(BibleSpeechlet.java:76) at com.amazon.speech.speechlet.SpeechletRequestDispatcher.dispatchSpeechletCall(SpeechletRequestDispatcher.java:63) at com.amazon.speech.speechlet.SpeechletRequestHandler.handleSpeechletCall(SpeechletRequestHandler.java:69) at com.amazon.speech.speechlet.lambda.SpeechletRequestStreamHandler.handleRequest(SpeechletRequestStreamHandler.java:81) I have followed the code examples in the Session and WiseGuy example code. When the user makes an initial request and it is missing some data I set the known pieces of data into the session object like so: session.setAttribute("Book", intent.getSlot(bookSlot)); // both of these objects are of type Slot session.setAttribute("Chapter", intent.getSlot(chapterSlot)); SpeechletResponse response = new SpeechletResponse(); response.setShouldEndSession(false); response.setOutputSpeech(outputSpeech); response.setReprompt(reprompt); return response; Later, once the user has been reprompted, I try to access my saved session information like so: Slot book = (Slot) session.getAttribute("Book"); At this point I get the stack trace you see at the beginning of this post. I have logged out my session attributes at this point, it looks like this: INFO Session: {Book={name=Book, value=genesis}, Chapter={name=Chapter, value=2}} It looks like, under the hood, Slot is just a type of Map, but I still don't understand why I can't cast it to Slot when that is what I set? Any suggestions or more detailed examples around using Sessions?
jjaquinta avatar image
jjaquinta answered
Off the top of my head... I believe all session attributes should be strings. [code] session.setAttribute("Chapter", [b]intent.getSlot(chapterSlot)[/b]); [/code] this sets it to a slot. Shouldn't you need to do: [code] session.setAttribute("Chapter", intent.getSlot(chapterSlot)[b].getValue()[/b]); [/code] I may not be remembering the API right...
Bailey avatar image
Bailey answered
I must have missed that requirement in the API since the method signature accepts an Object, but I will try only passing String's tonight.
jjaquinta answered
I just know that, ultimately, it spits out JSON. So support for anything other than a String or Number would require a serializer and deserializer and I really don't think their APIs are that sophisticated.
Nick Gardner avatar image
Nick Gardner answered
Jjaquinta is correct, the session attribute should be a string, and you'll get that error if you pass something that's not a string into the session object. -Nick
Kissell avatar image
Kissell answered
Can session attributes be used to store information between sessions? Like I have alexa open my skill, I interact with it and then the skill is done. Where can I store that information so that next time the skill is opened it can pick up where it left off without having to gather the user provided information again?
Jon avatar image
Jon answered
J. Kissell - no. Session attributes only store while the skill is running. If you want to persist across invocations of the skill you will need Dynamo, S3 or some other storage layer.
justin avatar image
justin answered
Thanks Jonathan! J. Kissell -- feel free to check out our Score Keeper sample for persisting values across different sessions for a user: https://developer.amazon.com/public/solutions/alexa/alexa-skills-kit/docs/using-the-alexa-skills-kit-samples
