Nen Xi avatar image
Nen Xi asked
Endpoint issue
Hi, I've been struggling with testing my new echo skill in the dev portal. I have some function that will make HTTP.GET from Yahoo API, it always displayed with error "The remote endpoint could not be called, or the response it returned was invalid." I also checked the history of alexa.amazon.com to find something useful about this error. It shows "Request Identifier: amzn1.echo-api.request.db935fdc-787f-4669-af11-d708ecd76298 The target Lambda application returned a failure response" Does anyone have met similar issue before? I assume it is related to my role/policy setting in the IAM that prevents this echo skill to send request to third party API. Thanks
jjaquinta avatar image
jjaquinta answered
Check the Lambda logs.
Nen Xi avatar image
Nen Xi answered
Thank you jiaquinta. I did check the Lamda log, which tells me a lot useful information, now the testing is passed with right JSON data returned. Thanks soooo much.
PhillyGirl avatar image
PhillyGirl answered
Can you share what your solution was?
