vandanapremkumar avatar image
vandanapremkumar asked
long number slot, what will be slot type ?
I'm using a thrid party api that has values with long number. If my slot is a long number example : "70150641234232418485". what will be the slot type ? Is there any issue with suck long number. I tried using AMAZON.NUMBER but it does not take long numbers.
Thanks, Vandana
alexa skills kitvoice-user interface
4 comments
vandanapremkumar avatar image vandanapremkumar commented ·
any help on this will be appreciated ?
Tried using literal
Tracking what is the status of {11111111111111111111|number}
Tracking what is the status of {22222222222222222222|number}
Tracking what is the status of {33333333333333333333|number}
Tracking what is the status of {44444444444444444444|number}
Tracking what is the status of {55555555555555555555|number}
Tracking what is the status of {66666666666666666666|number}
Tracking what is the status of {77777777777777777777|number}
Tracking what is the status of {88888888888888888888|number}
Tracking what is the status of {99999999999999999999|number}
got this error:
Error: There was a problem with your request: Incorrect syntax for the slot '{11111111111111111111|number}'. Each token must consist only of alphabets, white-spaces and valid punctuation marks. Valid punctuation marks are periods for abbreviations, possesive apostrophes and hyphens. Occurred in sample 'Tracking what is the status of {11111111111111111111|number}' on line 1.
newuser-271e6b21-4c8a-416e-854a-b0b5fb8f4f8c avatar image newuser-271e6b21-4c8a-416e-854a-b0b5fb8f4f8c vandanapremkumar commented ·
Rules for Sample Utterances
These rules also apply to any words specified inline in AMAZON.LITERAL slot values.
  • Numbers should be expressed as words and not digits (“five”, not “5”).
Reference: https://developer.amazon.com/public/solutions/alexa/alexa-skills-kit/docs/alexa-skills-kit-interaction-model-reference
Jamie Grossman avatar image Jamie Grossman ♦♦ commented ·
Investigating.
Jamie Grossman answered
Unfortunately, AMAZON.NUMBER doesn't support numbers with that many digits. You could try creating a custom slot type with the following values:
0 1 2 3 4 5 6 7 8 9 And then create multiple slots (with different names) that use that slot type. You could then create a sample utterance like:
Tracking what is the status of {SlotOne} {SlotTwo} {SlotThree} {SlotFour} {SlotFive} {SlotSix} {SlotSeven} {SlotEight} {SlotNine} {SlotTen} {SlotEleven} {SlotTwelve} {SlotThirteen} {SlotFourteen} {SlotFifteen} {SlotSixteen} {SlotSeventeen} {SlotEighteen} {SlotNineteen} {SlotTwenty}
If the value can be a variety of lengths, then you will need to create several sample utterances that include as many slots as necessary. Unfortunately, longer utterances tend to lead to more mis-recognitions, so the above sample utterance may not be very accurate. Also, when using the LITERAL slot type, values should be written out. So instead of:
Use:
Tracking what is the status of {one one one one one one one one one one one one one one one one one one one one|number}
If you wish to use LITERAL, you will need to provide as many sample utterances as possible since I assume that the value can be any combination of twenty digits.
