Pooja P. avatar image
Pooja P. asked
Device discovery of 'offline' devices
Say the first time the user ran the device discovery, and it found 4 devices.
Now one of the devices lost server connection and is offline.
then when alexa runs device discovery in the background, the Lambda skill returned only 3 that it found online.
But in the Alexa app, it shows up as 8 devices: original 4 + new 4 with 1 marked as offline.
Shouldn't it show only 3 and the 4th as offline ?..
When exactly are devices marked as "offline" in the alexa app?
alexa skills kitdevices
Brian@Amazon avatar image
Brian@Amazon answered
Hi Pooja. Is this on a current live smarthome skill or one that you are developing?
3 comments
@Brian@Amazon, its on a skill i am currently developing. My Lambda function returns only online devices.. So again: if originally 2 online devices were discovered, lambda returned 2; then if one went offline, Lambda is going to return only 1 device back to Alexa in the next discovery.. is this the right behaviour?
-1 Like -1 ·
I believe that is acceptable behavior, per the spec. If the discovery isn't run but the device isn't detected, it shoudl show as offline.
Okay, thanks Brian!
