newuser-d2507e75-5e6c-4710-a5f3-8d7d577a8649 avatar image
Alexa Not Recognizing Built-in Intents
Alexa is not recognizing my built-in intents: AMAZON.HelpIntent and AMAZON.StartIntent. It is instead simply calling my custom intents when commands like "Stop", "Help", and "Cancel" are uttered. I have implemented these intents in my interaction model and handled these cases in my lambda code (as stated in the guide), and it still does not work. What should I change to fix this?
Here is the interaction model:
  "intents": [
      "intent": "AMAZON.HelpIntent"
      "intent": "AMAZON.StopIntent"
      "intent": "GetMovieReview",
      "slots": [
          "name": "Movie",
          "type": "MOVIE"
      "intent": "GetTVShowReview",
      "slots": [
          "name": "TV_Show",
          "type": "TV_SHOW"
alexa skills kithelpintentsbuilt-in library
D. Young avatar image
D. Young answered
Apologies if this is too basic, but did you double check that you defined a handler for the help intent? If you are using the Alexa Skills Kit SDK for Node.js, did you register your handler?
davey avatar image
davey answered
Following up on this one. I had the same problem, and it's also with the AMAZON.Movie built-in colliding (seemingly) with the AMAZON.HelpIntent
