newuser-947e842b-2a51-47d8-bd6b-a303587233ae avatar image
newuser-947e842b-2a51-47d8-bd6b-a303587233ae asked ·
Opening a downchannel stream using nodejs gives Error: connect ECONNREFUSED?
I'm trying to establish a downchannel stream with AVS using the http2 module for nodejs.
This is my current request:
// open downchannel stream to AVS
	var options = {
		method: 'GET',
		scheme: 'https',
		host: 'avs-alexa-na.amazon.com',
		path: '/v20160207/directives',
		port: 80,
		auth: 'Bearer ' + token
	var req = http2.request(options, (res) => {
		console.log('statusCode: ', res.statusCode);
		console.log('headers: ', res.headers);
		res.on('data', (d) => {
			process.stdout.write(d);
	req.on('error', (e) => {
		console.error(e);
	req.end();
This is the error code that I receive:
{ [Error: connect ECONNREFUSED 54.239.21.157:80]
  code: 'ECONNREFUSED',
  errno: 'ECONNREFUSED',
  syscall: 'connect',
  address: '54.239.21.157',
  port: 80 }
Does anyone know what's going on here?
alexa voice servicenode_js
Hao@Amazon avatar image
Hao@Amazon answered ·
Have you tried sending events without establishing the down channel? Another thing to check is if your NodeJS support http2?
Lasse Sprengel avatar image
Lasse Sprengel answered ·
Try using port 443 (Default for encrypted traffic) instead of 80.
I tried using http2 as well and had some troubles. I then switched to spdy, which is able to connect but I am getting only empty (204) responses.
Let me know if you find a solution :)
