Ovi avatar image
Ovi asked ·
Error: Feed doesn't contain any items
Before I left for Christmas vacation my development Flash Briefing was working just fine. I just came back and everything is failing. I return an array with two items but the Developer Console always reports "Error: Feed doesn't contain any items"
I even tried returning the official examples from https://developer.amazon.com/public/solutions/alexa/alexa-skills-kit/docs/flash-briefing-skill-api-feed-reference and I still cannot get it to load.
Did anything change in the last two weeks or so?
alexa skills kitecho
I checked the call that the Developer portal is making and here is what I see: {"message":"Socket Timeout Error. Unable to retrieve content.","stackTrace":"","httpStatus":400,"exception":true}
My endpoint is 100% online, so I wonder if this is a problem with Amazon's HTTP crawler.
Ovi avatar image
Ovi answered ·
If anybody else is having this issue, it turned out that this is actually an Amazon bug.
Here is what I tried and how to fix it:
- I tried using different endpoint URLs (not only my URLs, but URLs of other skills that work). The dev portal was returning the same error for any URL.
- Then I tried recreating the briefing skill (using the same URLs!) and it worked. So just recreate the skill.
Amazon, please fix it and please make the errors more descriptive.
2 comments
Hi Ovi. Do you have the skillid for the skill which was impacted?
Ovi avatar image Ovi Brian@Amazon ♦ ·
amzn1.ask.skill.bb3ce25e-f01c-4f26-b3f4-561313830a1c
