newuser-98fe1cc3-8b5c-4a68-840d-9e321bcbe0c2 avatar image
newuser-98fe1cc3-8b5c-4a68-840d-9e321bcbe0c2 asked ·
How to identify Amazon Fire TV and Fire Stick in code level (HTML/JavaScript) ..?
I have developed a Fire TV application using HTML5 and JavaScript. That app is for Amazon Fire TV and Amazon Fire Stick. I need to identify what is the currently accessing device. Either Amazon Fire TV or Amazon Fire Stick.
How can I do this using HTML/JavaScript..?
fire tvtestingapp
Jamie@Amazon avatar image
Jamie@Amazon answered ·
This should be able to help., so you can check it at the required level.
Jacek avatar image
Jacek answered ·
Thanks Jamie, that helps on the server side!
Is there a way to get that info in the app built using Web App Starter Kit? Are those strings somehow accessible as well?
Joseph Shelby avatar image
Joseph Shelby answered ·
My code in SubFire is attached. I'm not picky about version numbers, as I have some degree of 'feature detection' in my code to determine that the WebKit version is old and I have to insert certain hacks for the audio tag.
var ua = navigator.userAgent;
if (ua.indexOf('cordova-amazon-fireos')>=0) {
  window.isFire = true;
  if (ua.indexOf('; AFT') >=0) {
    window.isFireTV = true;
  } else {
    window.isTablet = true;
    window.isKindleFire = ua.indexOf('; KF') >=0;
    window.isFirePhone = ua.indexOf('; SD4930UR') >= 0;
Thank you Joseph, that was exactly what I was looking for!
