newuser-86542da4-8015-4422-8ba6-4d02f7fe19f6 avatar image
giving a string slot in Amazon alexa
I'm new to alexa. I learnt and started to build a weather app.
right now I'm able to get weather data, but on the below condition,
  1. I've craeated a custom slot(LIST_OF_CITIES) to hold Cities as below.
  "intents": [
      "intent": "WeatherIntent",
      "slots": [
          "name": "city",
          "type": "LIST_OF_CITIES"
      "intent": "AMAZON.HelpIntent"
and in my custom slot I gave as below.
TypeValuesLIST_OF_CITIESHyderabad | pune | london
and below are my Utterances
WeatherIntent give me {city} climate
WeatherIntent {city}
WeatherIntent what's the climate in {city}
WeatherIntent what's the weather in {city}
when I run my program using any of the three cities mentioned in the above table, I'm able to get the correct. If I use anything apart from the above, it is sending back value as -4.
If I want to get tempreature of some other city, I need to add that city in the slot list.
Please let me know how can I get the vaues dynamically, I mean with out depending on the LIST_OF_CITIES, If I enter a city name, it should send back the result.
Also I tried adding type as LITERAL and also as AMAZON.LITERAL. When I saved it, I get the exception as
Error: There was a problem with your request: Unknown slot name '{city}'. Occurred in sample 'WeatherIntent get me weather of {city}' on line 1.
Please let me know where am I going wrong and how can I fix this.
alexa skills kithow-to
Jamie Grossman avatar image
Jamie Grossman answered
If you're looking to build a slot type for cities, you don't need to; we have some built in ones you can use here. You could probably keep the sample utterances the same and incorporate this slot type instead for which ever region you're working with. For example, AMAZON.AT_CITY would be for cities in Austria.
