newuser-8db982a8-8367-4303-a6d5-d10866cf7c75 avatar image
Cannot create AudioDevice
ERROR com.amazon.alexa.avs.AVSAudioPlayer - An error occurred while trying to play audio javazoom.jl.decoder.JavaLayerException: Cannot create AudioDevice at javazoom.jl.player.FactoryRegistry.createAudioDevice(FactoryRegistry.java:97) ~[jlayer-1.0.1.jar:?] at javazoom.jl.player.Player.<init>(Player.java:97) ~[jlayer-1.0.1.jar:?] at javazoom.jl.player.Player.<init>(Player.java:82) ~[jlayer-1.0.1.jar:?] at com.amazon.alexa.avs.AVSAudioPlayer$5.run(AVSAudioPlayer.java:837) [classes/:?]
alexa voice servicedevices
Nick_s@Amazon avatar image
Nick_s@Amazon answered
It looks like the application is unable to use the speaker on your device. In order to help diagnose, would you be able to provide the device type and OS where you're running the java client?
dlan avatar image
dlan answered
hello, I'm just encountering the same issue, any idea why?
here is full java backtrace,
btw, I'm using pulseaudio here, and I've tested with 'parecord' (to record the sound), then have no problem to play it back with 'paplay'
$ mvn exec:exec [INFO] Scanning for projects... [INFO] [INFO] ------------------------------------------------------------------------ [INFO] Building Alexa Voice Service Sample Java Client 20160207.2 [INFO] ------------------------------------------------------------------------ [INFO] [INFO] --- exec-maven-plugin:1.2.1:exec (default-cli) @ sample-java-client --- 17:25:49.526 [AWT-EventQueue-0] ERROR com.amazon.alexa.avs.AVSApp - An error occured creating speech request java.lang.NullPointerException at com.amazon.alexa.avs.AVSController.getMicrophoneInputStream(AVSController.java:304) ~[classes/:?] at com.amazon.alexa.avs.AVSController.startRecording(AVSController.java:282) [classes/:?] at com.amazon.alexa.avs.AVSApp$3.actionPerformed(AVSApp.java:265) [classes/:?] at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) [?:1.8.0_112] at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) [?:1.8.0_112] at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) [?:1.8.0_112] at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) [?:1.8.0_112] at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) [?:1.8.0_112] at java.awt.Component.processMouseEvent(Component.java:6533) [?:1.8.0_112] at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) [?:1.8.0_112] at java.awt.Component.processEvent(Component.java:6298) [?:1.8.0_112] at java.awt.Container.processEvent(Container.java:2236) [?:1.8.0_112] at java.awt.Component.dispatchEventImpl(Component.java:4889) [?:1.8.0_112] at java.awt.Container.dispatchEventImpl(Container.java:2294) [?:1.8.0_112] at java.awt.Component.dispatchEvent(Component.java:4711) [?:1.8.0_112] at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888) [?:1.8.0_112] at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525) [?:1.8.0_112] at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466) [?:1.8.0_112] at java.awt.Container.dispatchEventImpl(Container.java:2280) [?:1.8.0_112] at java.awt.Window.dispatchEventImpl(Window.java:2746) [?:1.8.0_112] at java.awt.Component.dispatchEvent(Component.java:4711) [?:1.8.0_112] at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) [?:1.8.0_112] at java.awt.EventQueue.access$500(EventQueue.java:97) [?:1.8.0_112] at java.awt.EventQueue$3.run(EventQueue.java:709) [?:1.8.0_112] at java.awt.EventQueue$3.run(EventQueue.java:703) [?:1.8.0_112] at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_112] at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80) [?:1.8.0_112] at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90) [?:1.8.0_112] at java.awt.EventQueue$4.run(EventQueue.java:731) [?:1.8.0_112] at java.awt.EventQueue$4.run(EventQueue.java:729) [?:1.8.0_112] at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_112] at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80) [?:1.8.0_112] at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) [?:1.8.0_112] at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) [?:1.8.0_112] at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) [?:1.8.0_112] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) [?:1.8.0_112] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) [?:1.8.0_112] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) [?:1.8.0_112] at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) [?:1.8.0_112] 17:25:49.540 [Thread-16] ERROR com.amazon.alexa.avs.AVSAudioPlayer - An error occurred while trying to play audio javazoom.jl.decoder.JavaLayerException: Cannot create AudioDevice at javazoom.jl.player.FactoryRegistry.createAudioDevice(FactoryRegistry.java:97) ~[jlayer-1.0.1.jar:?] at javazoom.jl.player.Player.(Player.java:97) ~[jlayer-1.0.1.jar:?] at javazoom.jl.player.Player.(Player.java:82) ~[jlayer-1.0.1.jar:?] at com.amazon.alexa.avs.AVSAudioPlayer$5.run(AVSAudioPlayer.java:918) [classes/:?] Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException at com.amazon.alexa.avs.AVSController.stopRecording(AVSController.java:550) at com.amazon.alexa.avs.AVSApp$3.actionPerformed(AVSApp.java:271) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.AbstractButton.doClick(AbstractButton.java:376) at javax.swing.AbstractButton.doClick(AbstractButton.java:356) at com.amazon.alexa.avs.AVSApp$3$1.onRequestError(AVSApp.java:261) at com.amazon.alexa.avs.AVSController.startRecording(AVSController.java:289) at com.amazon.alexa.avs.AVSApp$3.actionPerformed(AVSApp.java:265) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6533) at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) at java.awt.Component.processEvent(Component.java:6298) at java.awt.Container.processEvent(Container.java:2236) at java.awt.Component.dispatchEventImpl(Component.java:4889) at java.awt.Container.dispatchEventImpl(Container.java:2294) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466) at java.awt.Container.dispatchEventImpl(Container.java:2280) at java.awt.Window.dispatchEventImpl(Window.java:2746) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90) at java.awt.EventQueue$4.run(EventQueue.java:731) at java.awt.EventQueue$4.run(EventQueue.java:729) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80) at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Sanjay avatar image
Sanjay answered
Hey Dlan,
Could you provide the device type and OS that you're running the java client on?
Thanks,
Sanjay
newuser-d7895b11-e4d9-431e-b13b-ff4fc1e8de41 avatar image
newuser-d7895b11-e4d9-431e-b13b-ff4fc1e8de41 answered
Also have this exact issue
[INFO]
[INFO] Building Alexa Voice Service Sample Java Client 20160207.6
[INFO]
23:24:29.281 [Thread-28] ERROR com.amazon.alexa.avs.AVSAudioPlayer - An error occurred while trying to play audio
	at com.amazon.alexa.avs.AVSAudioPlayer$5.run(AVSAudioPlayer.java:932) [classes/:?]
23:24:41.724 [Thread-29] ERROR com.amazon.alexa.avs.AVSAudioPlayer - An error occurred while trying to play audio
Raspberry Pi 3
Rasbian Jessie
Follow instructions here exactly: https://github.com/alexa/alexa-avs-sample-app/wiki/Raspberry-Pi
The instructions at that url do not work. I've tried start to finish 3 times. Please fix.
