newuser-60294d69-b10a-461c-85b2-870caba82da7 avatar image
newuser-60294d69-b10a-461c-85b2-870caba82da7 asked ·
connection timed out
this is why?
I run javaclient (mvn validate,mvn install,mvn exec:exec) There is no wrong.but I run (mvn exec:java) is wrong.An error is as follows:
[INFO] --- exec-maven-plugin:1.2.1:java (default-cli) @ sample-java-client --- [INFO] ------------------------------------------------------------------------ [INFO] BUILD FAILURE [INFO] ------------------------------------------------------------------------ [INFO] Total time: 5.691 s [INFO] Finished at: 2016-08-25T15:01:05+08:00 [INFO] Final Memory: 9M/65M [INFO] ------------------------------------------------------------------------ [ERROR] Failed to execute goal org.codehaus.mojo:exec-maven-plugin:1.2.1:java (d efault-cli) on project sample-java-client: Unable to parse configuration of mojo org.codehaus.mojo:exec-maven-plugin:1.2.1:java for parameter arguments: Cannot store value into array: ArrayStoreException -> [Help 1] [ERROR] [ERROR] To see the full stack trace of the errors, re-run Maven with the -e swit ch. [ERROR] Re-run Maven using the -X switch to enable full debug logging. [ERROR] [ERROR] For more information about the errors and possible solutions, please rea d the following articles: [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginConfigur ationException
my ssl.cfg and config.json file is correct.
this is my pom.xml file:
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd"> <modelVersion>4.0.0</modelVersion> <groupId>com.amazon.alexa.avs</groupId> <artifactId>sample-java-client</artifactId> <version>20160207.0</version> <packaging>jar</packaging> <name>Alexa Voice Service Sample Java Client</name> <url>https://developer.amazon.com/appsandservices/solutions/alexa/alexa-voice-service</url> <properties> <jetty.version>9.3.7.v20160115</jetty.version> <!-- The latest version of alpn-boot that supports JDK 1.8.0_71 through 1.8.0_74 --> <!-- To override, pass -Dalpn-boot.version=YOUR_VERSION when running "mvn install" and "mvn exec:exec" --> <!-- Your version can be determined here: http://www.eclipse.org/jetty/documentation/current/alpn-chapter.html#alpn-versions --> <alpn-boot.version>8.1.7.v20160121</alpn-boot.version> <slf4j.version>1.7.10</slf4j.version> <log4j.version>2.3</log4j.version> <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding> </properties> <dependencies> <dependency> <groupId>commons-codec</groupId> <artifactId>commons-codec</artifactId> <version>1.9</version> </dependency> <dependency> <groupId>commons-io</groupId> <artifactId>commons-io</artifactId> <version>2.4</version> </dependency> <dependency> <groupId>org.apache.commons</groupId> <artifactId>commons-lang3</artifactId> <version>3.4</version> </dependency> <dependency> <groupId>commons-fileupload</groupId> <artifactId>commons-fileupload</artifactId> <version>1.3.1</version> </dependency> <dependency> <groupId>uk.co.caprica</groupId> <artifactId>vlcj</artifactId> <version>2.4.1</version> </dependency> <dependency> <groupId>org.glassfish</groupId> <artifactId>javax.json</artifactId> <version>1.0.4</version> </dependency> <dependency> <groupId>javazoom</groupId> <artifactId>jlayer</artifactId> <version>1.0.1</version> </dependency> <dependency> <groupId>org.mortbay.jetty.alpn</groupId> <artifactId>alpn-boot</artifactId> <version>${alpn-boot.version}</version> </dependency> <dependency> <groupId>org.codehaus.jackson</groupId> <artifactId>jackson-mapper-asl</artifactId> <version>1.9.13</version> </dependency> <dependency> <groupId>org.slf4j</groupId> <artifactId>slf4j-api</artifactId> <version>${slf4j.version}</version> </dependency> <dependency> <groupId>org.apache.logging.log4j</groupId> <artifactId>log4j-slf4j-impl</artifactId> <version>${log4j.version}</version> </dependency> <dependency> <groupId>org.apache.logging.log4j</groupId> <artifactId>log4j-core</artifactId> <version>${log4j.version}</version> </dependency> <!-- Jetty 9.3.7-SNAPSHOT --> <dependency> <groupId>org.eclipse.jetty</groupId> <artifactId>jetty-alpn-client</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>org.eclipse.jetty</groupId> <artifactId>jetty-http</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>org.eclipse.jetty.http2</groupId> <artifactId>http2-client</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>org.eclipse.jetty.http2</groupId> <artifactId>http2-http-client-transport</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>org.eclipse.jetty.http2</groupId> <artifactId>http2-hpack</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>org.eclipse.jetty.http2</groupId> <artifactId>http2-common</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>org.eclipse.jetty</groupId> <artifactId>jetty-server</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>org.eclipse.jetty</groupId> <artifactId>jetty-security</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>org.eclipse.jetty</groupId> <artifactId>jetty-servlet</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>org.eclipse.jetty</groupId> <artifactId>jetty-util</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>org.eclipse.jetty</groupId> <artifactId>jetty-io</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>org.eclipse.jetty</groupId> <artifactId>jetty-client</artifactId> <version>${jetty.version}</version> </dependency> <dependency> <groupId>javax.servlet</groupId> <artifactId>javax.servlet-api</artifactId> <version>3.1.0</version> </dependency> <dependency> <groupId>net.java.dev.jna</groupId> <artifactId>jna</artifactId> <version>4.1.0</version> <scope>compile</scope> </dependency> </dependencies> <build> <resources> <resource> <directory>src/main/resources</directory> <filtering>true</filtering> <includes> <include>**/*.properties</include> </includes> </resource> <!-- Don't filter the mp3 files or they'll get corrupted --> <resource> <directory>src/main/resources</directory> <filtering>false</filtering> <includes> <include>**/*.mp3</include> </includes> </resource> </resources> <pluginManagement> <plugins> <plugin> <groupId>org.apache.maven.plugins</groupId> <artifactId>maven-compiler-plugin</artifactId> <version>3.3</version> <configuration> <source>1.8</source> <target>1.8</target> <encoding>UTF-8</encoding> </configuration> </plugin> <plugin> <groupId>org.codehaus.mojo</groupId> <artifactId>exec-maven-plugin</artifactId> <version>1.2.1</version> <configuration> <executable>java</executable> <arguments> <argument>-Xbootclasspath/p:${settings.localRepository}/org/mortbay/jetty/alpn/alpn-boot/${alpn-boot.version}/alpn-boot-${alpn-boot.version}.jar</argument> <argument>-Dlog4j.configurationFile=file:///${basedir}/log4j2.xml</argument> <argument>-classpath</argument> <classpath/> <argument>-Djna.library.path=${env.VLC_PATH}</argument> <argument>com.amazon.alexa.avs.AVSApp</argument> </arguments> </configuration> </plugin> </plugins> </pluginManagement> </build> </project>
alexa voice serviceandroid
swasey@amazon avatar image
swasey@amazon answered ·
You shouldn't be running mvn exec:java, just mvn exec:exec. So if mvn exec:exec works, then you're good to go.
