pradyumna avatar image
pradyumna asked
End Point not accessible for testing
I have used a web service end point instead of a lambda . I can access the end point but amazon server is not able to access it . https://carista.in/echo.php The response from the end point is static {"version": "1", "sessionAttributes":{"supportedHoriscopePeriods":{"daily": true, "weekly": false, "monthly": false}}, "response":{"outputSpeech":{"type": "PlainText", "text": "Today will provide you a new learning opportunity. Stick with it and the possibilities will be endless. Can I help you with anything else?"}, "card":{"type": "Simple", "title": "Horoscope", "content": "Today will provide you a new learning opportunity. Stick with it and the possibilities will be endless."}, "reprompt":{"outputSpeech":{"type": "PlainText", "text": "Can I help you with anything else?"}}, "shouldEndSession": false}} Any help is appreciated
alexa skills kitdebugging
Galactoise avatar image
Galactoise answered
Are you using Lambda, or going directly to your service?
