paparika avatar image
paparika asked ·
can not get profile when requesting both alexa:all + profile scopes at the same time
my code has granted user auth for alexa successfully but can not get
user profile even if 'profile' scope is added. I can also confirm that I can
get profile separately without 'alexa:all' scope.
private static final String[] APP_SCOPES = {"profile", "alexa:all"};
Bundle options = new Bundle();
String scope_data = "{\"alexa:all\":{\"productID\":\"" + PRODUCT_ID +
        "\", \"productInstanceAttributes\":{\"deviceSerialNumber\":\"" +
        PRODUCT_DSN + "\"}}}";
options.putString(AuthzConstants.BUNDLE_KEY.SCOPE_DATA.val, scope_data);
options.putBoolean(AuthzConstants.BUNDLE_KEY.GET_AUTH_CODE.val, true);
options.putString(AuthzConstants.BUNDLE_KEY.CODE_CHALLENGE.val, CODE_CHALLENGE);
options.putString(AuthzConstants.BUNDLE_KEY.CODE_CHALLENGE_METHOD.val, "S256");
if(mAuthManager != null){
    mAuthManager.authorize(APP_SCOPES, options, new AuthListener());
private class AuthListener implements AuthorizationListener {
     * Authorization was completed successfully.
     * Display the profile of the user who just completed authorization
     * @param response bundle containing authorization response. Not used.
    @Override
    public void onSuccess(Bundle response) {
        final String authorizationCode = response.getString(AuthzConstants.BUNDLE_KEY.AUTHORIZATION_CODE.val);
        if(mAuthManager != null) {
            mAuthManager.getProfile(new APIListener(){
                @Override
                public void onSuccess(Bundle bundle) {
                    // Retrieve the data we need from the Bundle
                    Bundle profileBundle = bundle.getBundle(
                            AuthzConstants.BUNDLE_KEY.PROFILE.val);
			//profileBundle is always null !!
                @Override
                public void onError(AuthError authError) {
     * There was an error during the attempt to authorize the application.
     * Log the error, and reset the profile text view.
     * @param ae the error that occurred during authorize
    @Override
    public void onError(final AuthError ae) {
     * Authorization was cancelled before it could be completed.
     * A toast is shown to the user, to confirm that the operation was cancelled, and the profile text view is reset.
     * @param cause bundle containing the cause of the cancellation. Not used.
    @Override
    public void onCancel(Bundle cause) {
alexa voice servicealexa
Eric@Amazon avatar image
Eric@Amazon answered ·
10 comments
but my security profile already appears in the form 'Login with Amazon Configurations'
I found Consent Privacy Notice URL and Consent Logo Image is showing when I try to login with amazon to enable alexa, so this means my security profile is ok?
I confirmed I can get user profile if APP_SCOPES is set just as {"profile"}
I'm not sure if it is a bug, but if I request with scope {"profile"} first , then request with {"profile","alexa:all"}, I can get user profile as expected
I'm sorry, I forgot to mention that. Since the alexa:all scope is designed as a device linking scope, it should be requested in a separate authorization request other than the profile scope (which gets account information).
so you mean I have to request for them separately? but I'm confused what to do, apparently I don't want to popup the login dialog twice, right?
paparika answered ·
As per Amazon implementation, we get either AccessToken or Authorization code. In case of Authorization grant, we can't get user information
newuser-396f49f8-7297-4c1e-9806-fd573a3dc7c7 avatar image
newuser-396f49f8-7297-4c1e-9806-fd573a3dc7c7 answered ·
1. https://developer.amazon.com/docs/alexa-voice-service/authorize-companion-site.html
2. "SCOPE":"alexa:all profile"
Reminder there is a space in between
3. Then use the token (with profile scope now) to call this API as below:
https://developer.amazon.com/docs/login-with-amazon/obtain-customer-profile.html
