My application crashes when I try to set the appKey for the AmazonAdRegistration class.
My code:
AmazonAdRegistration.sharedRegistration().setAppKey("123")
The other methods on the AmazonAdRegistration class work fine. For eg: the following lines do work:
print("Amazon version: \(AmazonAdRegistration.sharedRegistration().sdkVersion())") AmazonAdRegistration.sharedRegistration().setLogging(true)
The logs show that the app crashes somewhere at a class called AMAdConfiguration.
Crash details below:
2016-06-22 16:32:03.193 BreathePlus[11186:2674778] *** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '-[__NSCFConstantString URLEncodedString]: unrecognized selector sent to instance 0x107704f88'
*** First throw call stack:
0 CoreFoundation 0x000000010acfdd85 __exceptionPreprocess + 165
1 libobjc.A.dylib 0x000000010a011deb objc_exception_throw + 48
2 CoreFoundation 0x000000010ad06d3d -[NSObject(NSObject) doesNotRecognizeSelector:] + 205
3 CoreFoundation 0x000000010ac4ccfa ___forwarding___ + 970
4 CoreFoundation 0x000000010ac4c8a8 _CF_forwarding_prep_0 + 120
5 BreathePlus 0x0000000107518617 -[AMAdConfiguration setApplicationId:applicationName:userSpecifiedMarketplace:] + 85
6 BreathePlus 0x000000010752256d -[AmazonAdRegistration setAppKey:] + 93
7 BreathePlus 0x00000001074e7161 _TFFC11BreathePlus11AppDelegate11applicationFTCSo13UIApplication29didFinishLaunchingWithOptionsGSqGVs10DictionaryCSo8NSObjectPs9AnyObject____SbU_FT_T_ + 1041
8 BreathePlus 0x00000001074b1717 _TTRXFo__dT__XFdCb__dT__ + 39
9 libdispatch.dylib 0x000000011033dd9d _dispatch_call_block_and_release + 12
10 libdispatch.dylib 0x000000011035e3eb _dispatch_client_callout + 8
11 libdispatch.dylib 0x0000000110343686 _dispatch_after_timer_callback + 334
12 libdispatch.dylib 0x000000011035e3eb _dispatch_client_callout + 8
13 libdispatch.dylib 0x00000001103517e5 _dispatch_source_latch_and_call + 1750
14 libdispatch.dylib 0x000000011034c770 _dispatch_source_invoke + 1057
15 libdispatch.dylib 0x0000000110346051 _dispatch_main_queue_callback_4CF + 1324
16 CoreFoundation 0x000000010ac570f9 __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9
17 CoreFoundation 0x000000010ac18b99 __CFRunLoopRun + 2073
18 CoreFoundation 0x000000010ac180f8 CFRunLoopRunSpecific + 488
19 GraphicsServices 0x000000010d989ad2 GSEventRunModal + 161
20 UIKit 0x00000001079edf09 UIApplicationMain + 171
21 BreathePlus 0x00000001074e6bb2 main + 114
22 libdyld.dylib 0x000000011039292d start + 1
23 ??? 0x0000000000000001 0x0 + 1
libc++abi.dylib: terminating with uncaught exception of type NSException
