zzmehdi avatar image
zzmehdi asked
Alexa Access Token- ["alexa:all"] parameter for requestScopes
Hi all, I'm trying to get an access token for an iOS app in Swift. After creating Amazon login and ensuring it works, I added the methods to obtain an access token listed here. https://developer.amazon.com/public/solutions/alexa/alexa-voice-service/docs/authorizing-your-alexa-enabled-mobile-app#Resources
Below you can see the methods for loginButtonTouched and checkIsUserSignedIn. Previously the code worked with the requestScope parameters as ["profile","postal_code"]. However, adding the requestScope parameter as ["alexa:all"] seems to result in a bug.
Instead of allowing a user to complete login once login button is touched and then returning to the app, the browser doesn't finish loading and returns to the app. Setting up breakpoints shows that after clicking login, and when the browser is in the midst of loading, it goes to the App Delegate and isValidRedirectSignInURL returns false. That's when the browser doesn't finish loading and returns to the app. Any help would be much appreciated! Thank you!
//method for tapping login button
@IBAction func loginButtonTouched(sender: UIButton) {
  let productId = "ABC123"
  let deviceSerialNumber = "123"
 let amazonAuthorizeUserDelegate = AMZNAuthorizeUserDelegate()
 let requestScopes = ["alexa:all"]
 var options = [String:AnyObject]()
 let scopeData = String(format:"{\"alexa:all\":{\"productID\":\"%@\", ", "\"productInstanceAttributes\":{\"deviceSerialNumber\":\"%@\"}}}", productId, deviceSerialNumber)
  options[kAIOptionScopeData] = scopeData
  AIMobileLib.authorizeUserForScopes(requestScopes, delegate:amazonAuthorizeUserDelegate, options: options)
//method for checking if user is signed in
func checkIsUserSignedIn() {
  let amazonGetAccessTokenDelegate = AMZNGetAccessTokenDelegate()
  AIMobileLib.getAccessTokenForScopes(requestScopes, withOverrideParams: nil, delegate: amazonGetAccessTokenDelegate)
alexa voice service
luandrecast avatar image
luandrecast answered
Hi @zzmehdi
Check out this Sample repo , hope it helps.
