mrus avatar image
mrus asked
amazon mobile ads unity iOS crashes
hello,
my app with amazon mobile ads via unity works for android. but if i test the iOS app, it closes if i call a banner. I get this error:
Anyone has an idea whats wrong?
(Filename: /Users/builduser/buildslave/unity/build/artifacts/generated/common/runtime/UnityEngineDebugBindings.gen.cpp Line: 37)
AmazonMobileAdsUnityIPhone: Successfully called native code in 9 ms
UnityEngine.Logger:Log(LogType, Object)
UnityEngine.Debug:Log(Object)
com.amazon.mas.cpt.ads.AmazonMobileAdsBase:LoadAndShowFloatingBannerAdJson(String)
com.amazon.mas.cpt.ads.AmazonMobileAdsBase:LoadAndShowFloatingBannerAd(Ad)
AdTest:DisplayFloatingAd(Boolean)
UnityEngine.Events.InvokableCallList:Invoke(Object[])
UnityEngine.UI.Button:Press()
UnityEngine.EventSystems.ExecuteEvents:Execute(IPointerClickHandler, BaseEventData)
UnityEngine.EventSystems.ExecuteEvents:Execute(GameObject, BaseEventData, EventFunction`1)
UnityEngine.EventSystems.StandaloneInputModule:ProcessTouchPress(PointerEventData, Boolean, Boolean)
UnityEngine.EventSystems.StandaloneInputModule:ProcessTouchEvents()
UnityEngine.EventSystems.StandaloneInputModule:Process()
UnityEngine.EventSystems.EventSystem:Update()
System.Array:GetGenericValueImpl(Int32, T&)
2016-05-26 12:40:33.202 photoplay[206:6371] Ad Failed to load. Error code 1: Try again in 9.999959 seconds.
2016-05-26 12:40:33.202 photoplay[206:6371] Ad has failed to load
AmazonMobileAdsUnityIPhone: eventReceived
com.amazon.mas.cpt.ads.AmazonMobileAdsImpl:FireEvent(String)
Unhandled Exception: System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
  at System.Collections.ObjectModel.Collection`1[T].CheckWritable (IList`1 list) [0x00000] in <filename unknown>:0
  at System.Collections.Generic.Dictionary`2[TKey,TValue].get_Item (.TKey key) [0x00000] in <filename unknown>:0
  at com.amazon.mas.cpt.ads.AmazonMobileAdsImpl.FireEvent (System.String jsonMessage) [0x00000] in <filename unknown>:0
  at System.Array.GetGenericValueImpl[T] (Int32 pos, .T& value) [0x00000] in <filename unknown>:0
UnityEngine.Debug:LogError(Object)
UnityEngine.UnhandledExceptionHandler:PrintException(String, Exception)
UnityEngine.UnhandledExceptionHandler:HandleUnhandledException(Object, UnhandledExceptionEventArgs)
photoplay was compiled with optimization - stepping may behave oddly; variables may not be available.
(lldb)
mobile adsiosunity
HunterGames avatar image
HunterGames answered
I have same problem can't find a solution anywhere
Sindy@Amazon avatar image
Sindy@Amazon answered
Hi! Are you still experiencing this issue? Please let us know and we will escalate. Thanks!
AppyNation Ltd. avatar image
AppyNation Ltd. answered
This might be similar to an issue I posted here.
Try adding handlers for all event not just the ones you use.
