tkw722 avatar image
tkw722 asked
"Invalid Grant Parameter: redirect_uri" on Product Authenticating For AVS
Hi All, Back again, with some further progress but still stuck. I am writing a Swift iOS app that acts as the companion app to a device that will be interacting with the Alexa Voice Service. I believe I have the iOS side correctly authenticating and retrieving a valid authorization code. The app passes the authorization code to the device and then the device makes a REST call to the OAuth endpoint to trade it for the access token. This is where I'm running into a problem. When making a call to the OAuth endpoint, I get the response: { error_description : The request has an invalid grant parameter : redirect_uri, error : invalid_grant } I have followed the instructions defined in " https://developer.amazon.com/public/solutions/alexa/alexa-voice-service/docs/authorizing-your-alexa-enabled-product-from-an-android-or-ios-mobile-app" and it states to retrieve the redirect_uri by calling [AIMobileLib getRedirectUri]. Based on what I've read elsewhere it seems that the redirect_uri should match the original one used to retrieve the authorization code. It's my assumption that [AIMobileLib getRedirectUri] returns that. Regardless, in the situation where a separate device is trading the auth code for the access token, a redirect_uri doesn't seem to make sense. Has anyone else run into this? What's the correct content to submit for this field when a separate device is being authenticated? Any help would be greatly appreciated! Thanks, Tim
login with amazon
Jamie Grossman avatar image
Jamie Grossman answered
Hi there, I've looked into this issue, but I'm still not 100% on what is going on. Before passing it on to the relevant team, were you able to solve this issue in the end? Thanks! Jamie
