kiran-igo avatar image
kiran-igo asked
Exception on trying to init ADM
I get: java.lang.RuntimeException: Stub! at com.amazon.device.messaging.ADM. (Unknown Source) when trying to construct the ADM object on a Kindle Fire HD(System version: 7.3.1_user_3140720). Any ideas what I could be missing?
amazon device messaging
I am getting the same error on my API 22 Fire TV (i.e., Amazon AFTB, Lollipop, 5.1.1). However, when I run the exact same app on API 25 Fire TV (i.e., Amazon AFTN, Nougat 7.1.2) it runs absolutely fine with no RuntimeException.
Here is my build.gradle
apply plugin: 'com.android.application'android {
compileSdkVersion 26defaultConfig {
applicationId "com.anas.myapplication"minSdkVersion 15targetSdkVersion 26versionCode 1versionName "1.0"testInstrumentationRunner "android.support.test.runner.AndroidJUnitRunner"}
signingConfigs {
debug {
storeFile file("sample.jks")
storePassword 'anasanas'keyAlias 'key0'keyPassword 'anasanas'}
buildTypes {
release {
minifyEnabled falseproguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'}
dependencies {
implementation fileTree(include: ['*.jar'], dir: 'libs')
implementation 'com.android.support:appcompat-v7:26.1.0'implementation 'com.android.support.constraint:constraint-layout:1.0.2'testImplementation 'junit:junit:4.12'androidTestImplementation 'com.android.support.test:runner:1.0.1'androidTestImplementation 'com.android.support.test.espresso:espresso-core:3.0.1'compile files('libs/amazon-device-messaging-1.0.1.jar')
Please help me resolve this fast.
stephen-the-amazonian avatar image
stephen-the-amazonian answered
Thanks for your question. That exception can occur when you have included the ADM JAR in the APK. Instead, the JAR should just be included in the compiler's classpath. Please see https://developer.amazon.com/sdk/adm/setup.html for more information on the setup process. Thanks, Stephen
kiran-igo answered
Thanks. It looks like the jar file was being copied twice. Once into our ext_libs folder for our lib and then later into the app's libs folder which caused it to be packaged into the APK. Kiran
fuzzandroid avatar image
fuzzandroid answered
How do you do this on IntelliJ IDEA?
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi Fuzzandroid, Thank you for writing to us. In intellij you have to add ADM jar as dependency and scope should be "provided". Go to Project Structure (Ctrl+Alt+Shift+S), select "modules" from "Project Settings" in the left pane, select "Dependencies" tab from right pane. Click on "+" button, select jars or directories, then locate and select the ADM jar, change the scope of the jar as "provided". Make sure "export" check box is not checked.
OnAir_Player avatar image
OnAir_Player answered
Hi, I followed your instructions to add the ADM library on intellijIDEA but now I get this issue: java.lang.NoClassDefFoundError: com.myapp.services.ADMIntentService any idea why this is happening and how to fix it?
Which device you are testing on? And when the exception is thrown? Can you please paste the full logs? Thanks.
William Erickson avatar image
William Erickson answered
Have you updated your AndroidManifest.xml following these instructions? https://developer.amazon.com/public/apis/engage/device-messaging/tech-docs/04-integrating-your-app-with-adm#Update%20Your%20App%20Manifest I think you might be missing:
Alexander Farber avatar image
Alexander Farber answered
dependencies {
    compileOnly files('libs/amazon-device-messaging-1.0.1.jar')
    implementation files('libs/login-with-amazon-sdk.jar')
newuser-529a81eb-d5d7-4f71-b849-eba5c8921239 avatar image
newuser-529a81eb-d5d7-4f71-b849-eba5c8921239 answered
I have had the same issue. Problem was in xml namespace in manifest.
It should be like in documentation: xmlns:amazon="http://schemas.amazon.com/apk/res/android"
