Peter Varga avatar image
Peter Varga asked
How to create endpoint for Open/Close/Stop command?
I would like to add a door to the devices that has a capability Open, Close, Stop.
I can't figure out the right syntax for Alexa endpoint that I need to use for discovery.
I can add a door/garage_door with open/close but when I adding the Stop than Alexa can't discover the device. Is it possible to do it with "interface": "Alexa.ModeController"?
Here is the discovery respond:
"event": {
"header": {
"namespace": "Alexa.Discovery",
"name": "Discover.Response",
"payloadVersion": "3",
"messageId": "45a8c36c-d177-4efe-a966-02aa35dc0128"
"payload": {
"endpoints": [
"endpointId": "Unique ID",
"friendlyName": "Test Garage Door",
"description": "parseTest Test Garage Door Garage Door Opener",
"manufacturerName": "BETA",
"displayCategories": [
"EXTERIOR_BLIND"
"capabilities": [
"type": "AlexaInterface",
"interface": "Alexa",
"version": "3"
"interface": "Alexa.ModeController",
"instance": "GarageDoor.Position",
"version": "3",
"properties": {
"supported": [
"name": "mode"
"retrievable": true,
"proactivelyReported": true
"capabilityResources": {
"friendlyNames": [
"@type": "asset",
"value": {
"assetId": "Alexa.Setting.Mode"
"configuration": {
"ordered": false,
"supportedModes": [
"value": "Position.Up",
"modeResources": {
"friendlyNames": [
"@type": "asset",
"value": {
"assetId": "Alexa.Value.Open"
"value": "Position.Down",
"modeResources": {
"friendlyNames": [
"@type": "asset",
"value": {
"assetId": "Alexa.Value.Close"
"semantics": {
"actionMappings": [
"@type": "ActionsToDirective",
"actions": [
"Alexa.Actions.Close",
"Alexa.Actions.Lower"
"directive": {
"name": "SetMode",
"payload": {
"mode": "Position.Down"
"actions": [
"Alexa.Actions.Open",
"Alexa.Actions.Raise"
"directive": {
"name": "SetMode",
"payload": {
"mode": "Position.Up"
"stateMappings": [
"@type": "StatesToValue",
"states": [
"Alexa.States.Closed"
"states": [
"Alexa.States.Open"
device discovery
